原文由 waters5000 发表:
Chirality of the active substance, with all the isomers forms and specific rate that can influence on the efficiency and also on the security of the activesubstance. Present always assay results of the isomers when the analysis methodology is available. In case of the active substance presents chirality, the manufacture should send a statement about this.
这段话中的specific rate 是什么意思?谢谢专家指教!
总感觉这个句子晦涩难懂。
all the isomer
rates,
that can influence
on the
security(stability??) of the activesubstance.
Always present assay results of the isomers when the analysis methodology is available.
In case of If the active substance presents chirality, the manufacture should send a statement about this
situation (?).
