主题:【讨论】应助 旋转蒸发仪英语怎么说?
浏览0 回复9 电梯直达
东方逸
rotary evaporator or rotation evaporograph?
该帖子作者被版主 何当奇2积分, 2经验,加分理由:求助的好
您可能想找: 旋转蒸发仪 询底价
阳线
Rotary Evaporators
该帖子作者被版主 redanqi2积分, 2经验,加分理由:应助
闲鹤野云
原文由 hzsunmoon 发表:
Rotary Evaporators
这个是正确的翻译。
无名
chinayanghang
hello12345
happyjyl
evaporograph是由词根evapor(蒸发)和后缀graph(图表,曲线,书写,记录)组成的,中间用o连接。由此可见,evaporograph的功能不仅包括使溶液蒸发,还包括记录溶液蒸发的过程。这种用法与chromatography(色谱仪)相似。
jinruchen
chengjingbao
我觉得前者较好,后者仪器系统较复杂。
rotary evaporator
熊猫宝宝
Samples were extracted with 1∶1 acetonitrile and ethyl acetate followed by centrifuging. Then the supernatant was evaporated on a rotary evaporator until dry. And 1.0 mL of solution comprised of 30∶70 methanol and pure water was added into the bottle to dissolve the matters of interest and 0.5 mL of hexane was added to remove fat.After filtration with 0.45 μm membrane,the samples were analyzed by high performance liquid chromatography and tandem mass spectrometer.
    样品经过V(乙腈)∶V(乙酸乙酯)=1∶1混合溶剂提取后,离心,上清液在旋转蒸发仪上蒸发至干,体积分数30%甲醇溶液定容,正己烷除去脂肪,经过滤膜后,进高效液相色谱-串联四极杆质谱进行分析,内标法定量。
