在甲胺磷农药的检测的前处理过程中,由于甲胺磷自身的性质,提取和净化都是比较麻烦的。这个问题在论坛中讨论的也是较多的;这里有一些外文的相关甲胺磷农药的检测文献摘要,由于下载的权限所限,不能提供全文,抱歉!如果大家看了摘要之后,没有办法需要全文的,可以到文献求助-应助版面进行求助。
1.Determination of polar organophosphorus pesticides in aqueous samples by direct injection using liquid chromatography–tandem mass spectrometry Benno A. Ingelse, Ruud C. J. van Dam, Rob J. Vreeken, Hans G. J. Mol and Odile M. SteijgerAbstract:It was demonstrated that four out of six of the very polar organophosphorus pesticides (OPs), i.e. acephate, methamidophos, monocrotophos, omethoate, oxydemeton-methyl and vamidothion, could not be extracted from water using commonly available SPE cartridges. In addition,
gc analysis on all six compounds was found to be troublesome due to their polar and thermolabile character. This initiated the development of an alternative highly sensitive and selective method for the determination of the above mentioned very polar OPs in water, based on LC–MS. Large volume (1 ml) water samples were directly injected onto an RP18 HPLC column with a polar endcapping. The latter was essential for obtaining retention and maintaining column performance under 100% aqueous conditions during the sampling. The compounds were ionized using atmospheric pressure chemical ionization and detected on a tandem mass spectrometer operated in multiple reaction-monitoring mode. The detection limits were in the range of 0.01–0.03 μg/l. Compared to conventional
gc methods, the developed LC–MS procedure is very straightforward, fast and more reliable. This application demonstrates the applicability of LC–MS for analysis of polar OPs in surface, ground and drinking water, as a more favourable alternative to
gc.
Journal of Chromatography A
Volume 918, Issue 1, 18 May 2001, Pages 67-78 2.Determination of polar organophosphorus pesticides in vegetables and fruits using liquid chromatography with tandem mass spectrometry: selection of extraction solventHans G. J. Mol, , Ruud C. J. van Dam and Odile M. SteijgerAbstract:A method based on liquid chromatography (LC)–mass spectrometry (MS)/MS was developed for sensitive determination of a number of less gas chromatography (
gc)-amenable organophosphorus pesticides (OPs; acephate, methamidophos, monocrotophos, omethoate, oxydemeton-methyl and vamidothion) in cabbage and grapes. For extraction, several solvents were evaluated with respect to the possibility of direct injection, matrix-induced suppression or enhancement of response, and extraction efficiency. Overall, ethyl acetate was the most favourable solvent for extraction, although a solvent switch was required. For some pesticide/matrix combinations, reconstitution of the residue after evaporation required special attention. Extracts were analysed on a C18 column with polar endcapping. The pesticides were ionised using atmospheric pressure chemical ionisation on a tandem mass spectrometer in multiple reaction monitoring mode. The final method is straightforward and involves extraction with ethyl acetate and a solvent switch to 0.1% acetic acid/water without further cleanup. The method was validated at the 0.01 and 0.5 mg/kg level, for both cabbage and grapes. Recoveries were between 80 and 101% with R.S.D.<11% (n=5). The limit of quantification was 0.01 mg/kg and limits of detection were between 0.001 and 0.004 mg/kg.
Volume 1015, Issues 1-2, 10 October 2003, Pages 119-127
