yaya91回复于2008/06/05
是标示吧?药品的说明书或标签上写的规格。内容一般是含某种主药多少mg。
poorlittle回复于2008/06/05
呵呵,能不能详细描述一下?
From the meanings of the following information obtained from internet:
Not a single product met its label claim—some were close and some ... Label Claim. Per Capsule. Test Result. Per Capsule. Percent of Label ...
ineffective, and is used for label claim only.
to prove beyond doubt that it meets the label claim of a minimum protein ...
Lean Body Mass 60 is lab tested to meet the label claim of potency
According to a Consumer Council test,their actual down content, in many cases, was less than the label claim.
the test came back 4mg under label claim. ...
Knowing what's going into a specific label claim can help you understand the protection that vaccines will provide
闲鹤野云回复于2008/06/05
标示值????
youjian000回复于2008/06/05
提供一句语言环境:
These drugs contents were found to be in good agreement with the label claim values.
‘标签’标示量 ;标称量;标称值
我觉得“标称量”比较好,不知是否对?
