原文由 hyljohn 发表:
楼上说的没错,反正觉得软件有点问题,问过工程师,说是最新版的软件了....
yes, there are some bugs in the Varian SpectrAA software 5.1 Pro.
Called the technical support several times, was asked to pay attention on the report setting when "edit sequence parameters"/ then go to "Reports", select the "Print Report" and save the raw data.
That maybe help eliminate that problem. After that, the "raw date missing" and "failed to print" gone...
Pls see the attachment pictures.
