对不起,有点多,没办法,我没办法找到外文文献,只有在google找到了几篇,剩下只有求助各位,拜托。
1. Detection of Amadori compounds by capillary electrophoresis coupled to tandem mass spectrometry,
Hau J, Devaud S, Blank I.,Electrophoresis. 2004 Jul; 25(13):2077-83
2. Effective HPLC method for the determination of aromatic Amadori compounds
Shi-Jun Ge and Tung-Ching Lee* J. Agric. Food Chem., 44 (4), 1053 -1057, 1996. jf950494x
http://pubs.acs.org/cgi-bin/searchRedirect.cgi/jafcau/1996/44/i04/pdf/jf950494x.pdf
Detection of Amadori Compounds in Heated Foods
EICHNER, K REUTTER, M WITTMANN, R,THERMALLY GENERATED FLAVORS,1994
3. The preparation and characterization of some Amadori compounds (1-amino-1-deoxy-D-fructose derivatives) derived from a series of aliphatic omega-amino acids.
Mossine VV, Glinsky GV, Feather MS.,CARBOHYDRATE RESEARCH,1994 Sep 15;262(2):257-70.
4. STUDY ON THE DECOMPOSITION OF THE AMADORI COMPOUND N-(1-DEOXY-D-FRUCTOS-1-YL)-GLYCINE IN MODEL SYSTEMS - QUANTIFICATION BY FAST-ATOM-BOMBARDMENT TANDEM MASS-SPECTROMETRY
STAEMPFLI, AA BLANK, I FUMEAUX, R FAY, LB,BIOLOGICAL MASS SPECTROMETRY,1994,642-646
5. Chemistry of Amadori rearrangement products: analysis, synthesis, kinetics, reactions, and spectroscopic properties
Yaylayan VA, Huyghues-Despointes A., Crit Rev Food Sci Nutr. 1994;34(4):321-69
6. ISOLATION AND PURIFICATION OF AMADORI COMPOUNDS BY SEMI-PREPARATIVE REVERSED-PHASE HIGH-PERFORMANCE LIQUID-CHROMATOGRAPHY
MOLL, N GROSS, B,JOURNAL OF CHROMATOGRAPHY,1981,186-192
7. Electrospray positive ionization tandem mass spectrometry of Amadori compounds
Wang, J Lu, YM Liu, BZ He, HY,JOURNAL OF MASS SPECTROMETRY,2008,262-264
8. Separation of amino acids, peptides and corresponding Amadori compounds on a silica column at elevated temperature
Hao, ZG Lu, CY Xiao, BM Weng, ND Parker, B Knapp, M Ho, CT ,JOURNAL OF CHROMATOGRAPHY A,2007,165-171
9. A useful analytical tool for the characterization of Maillard reaction products in foods
Vallejo-Cordoba, B Gonzalez-Cordova, AF,ELECTROPHORESIS,2007,4063-4071
10. Analysis of Amadori compounds by high-performance cation exchange chromatography coupled to tandem mass spectrometry
Davidek, T Kraehenbuehl, K Devaud, S Robert, F Blank, L ,ANALYTICAL CHEMISTRY,2005,140-147
可以发到我邮箱里面:flyfolk@qq.com,或者flyfolk@tom.com,谢谢。
补充答案:
大陆回复于2008/06/15
4, 5年代较久没有电子版可用,请寻求馆藏途径。
