目录
基础
1 开启和关闭仪器---------------------------------------------------------------------------------------------------15
1.1 开启仪器-------------------------------------------------------------------------------------------------------15
1.1.1 开通仪器电源--------------------------------------------------------------------------------------------15
1.1.2 启动PCXRF软件-----------------------------------------------------------------------------------15
1.1.3 初始化仪器-----------------------------------------------------------------------------------------------16
1.1.4 开启 X射线----------------------------------------------------------------------------------------------16
1.2 关闭仪器-------------------------------------------------------------------------------------------------------17
1.2.1 关闭X射线-----------------------------------------------------------------------------------------------17
1.2.2 关闭PCXRF软件-----------------------------------------------------------------------------------17
1.2.3 关闭仪器电源--------------------------------------------------------------------------------------------17
2 软件的简要介绍---------------------------------------------------------------------------------------------------18
2.1 初始画面-------------------------------------------------------------------------------------------------------18
2.2 各部分功能----------------------------------------------------------------------------------------------------19
2.3 在线帮助-------------------------------------------------------------------------------------------------------20
2.4 分析类型-------------------------------------------------------------------------------------------------------20
2.5 分析组----------------------------------------------------------------------------------------------------------20
3 简单分析------------------------------------------------------------------------------------------------------------22
3.1 简单分析-------------------------------------------------------------------------------------------------------22
3.1.1 打开“analysis(分析)!窗口------------------------------------------------------------------------22
3.1.2 选择分析组-----------------------------------------------------------------------------------------------23
3.1.3 选择样品位置--------------------------------------------------------------------------------------------23
3.1.4 开始分析--------------------------------------------------------------------------------------------------23
3.1.5 测量过程数据显示--------------------------------------------------------------------------------------23
3.1.6 分析结果的确认-----------------------------------------------------------------------------------------23
3.2 一般操作-------------------------------------------------------------------------------------------------------24
3.2.1 打开“analysis(分析)!窗口------------------------------------------------------------------------24
3.2.2 选择一个分析组-----------------------------------------------------------------------------------------25
3.2.3 输入样品名称--------------------------------------------------------------------------------------------26
3.2.4 开始分析--------------------------------------------------------------------------------------------------27 应用软件
4.不同条件样品的分析------------------------------------------------------------------------------------------28
4.1 定性-定量分析(块状)---------------------------------------------------------------------------------28
4.1.1 建立分析条件-----------------------------------------------------------------------------------------28
1)建立一个新组-------------------------------------------------------------------------------------28
2)设置样品分析资料-------------------------------------------------------------------------------30
3)登记测量通道(元素)-------------------------------------------------------------------------30
4)登记内含元素-------------------------------------------------------------------------------------31
5)设置测量条件-------------------------------------------------------------------------------------31
6)设置熔剂-------------------------------------------------------------------------------------------32
7)设置波形显示及打印形式----------------------------------------------------------------------32
8)存储分析组----------------------------------------------------------------------------------------35
4.1.2分析未知样品-----------------------------------------------------------------------------------------35
1)选择分析组----------------------------------------------------------------------------------------35
2)输入样品名称-------------------------------------------------------------------------------------36
3)开始样品分析-------------------------------------------------------------------------------------36
4)查看分析结果-------------------------------------------------------------------------------------36
4.2 标准曲线法定量分析-------------------------------------------------------------------------------------37
4.2.1 建立分析条件--------------------------------------------------------------------------------------37
1)建立分析组-------------------------------------------------------------------------------------37
2)登记分析元素----------------------------------------------------------------------------------39
3)设置元素资料----------------------------------------------------------------------------------39
4)设置测量条件----------------------------------------------------------------------------------40
5)输入标准样品名称----------------------------------------------------------------------------40
6)输入标准样品标准值-------------------------------------------------------------------------41
7)存储分析组-------------------------------------------------------------------------------------42
