没错,DEHP 和DOP就是同一种物质,叫法不一样。
查化工词典可以得到下面的内容:
DEHP:
CAS NO.: 117-81-7
分子式: C24H38O4
分子量: 390.56
沸点: 384℃
熔点: -50-386℃
中文名称:
邻苯二甲酸二(α-乙基己酯)
1,2-苯二甲酸二(2-乙基己基)酯
增塑剂DOP
邻苯二甲酸二(A-乙基己酯)
邻苯二甲酸二(2-乙基己基)酯
邻苯二甲酸二(2-乙基已)酯
邻苯二甲酸二辛酯(DOP)
邻苯二酸二辛酯
苯二甲酸二辛酯
邻酞酸二正辛酯
DOP
邻苯二甲酸-2-乙基己酯
邻苯二甲酸二(2-乙基己)酯
酞酸二辛酯
邻苯二甲酸乙基己基酯
英文名称:
di(.alpha.-Ethylhexyl) phthalate
1,2-Benzenedicarboxylic acid, bis(2-ethylhexyl) ester
Dioctyl phthalate
phthalic acid, bis(2-ethylhexyl) ester
1,2-benzenedicarboxylic acid, bis(ethylhexyl) ester
2-ethylhexyl phthalate
ai3-04273
behp
bis(2-ethylhexyl)-1,2-benzenedicarboxylate
bis(2-ethylhexyl)phthalate
bis-(2-ethylhexyl)ester kyseliny ftalove
bisoflex 81
bisoflex dop
compound 889
daf 68
dehp
di(2-ethylhexyl)orthophthalate
di(2-ethylhexyl)phthalate
di(ethylhexyl) phthalate
di-(2-ethylhexyl)-phthalate
di-2-ethylhexylphthalate
di-sec-octyl phthalate
diethylhexyl phthalate
dof (russian plasticizer)
dop
ergoplast fdo
ergoplast fdo-s
eviplast 80
eviplast 81
fleximel
flexol dop
flexol plasticizer dop
good-rite gp 264
hatcol dop
hercoflex 260
jayflex dop
kodaflex dop
mollan o
nci-c52733
nuoplaz dop
octoil
octyl phthalate
palatinol ah
phthalic acid dioctyl ester
pittsburgh px-138
platinol ah
platinol dop
rc plasticizer dop
rcra waste number u028
reomol d 79p
reomol dop
sicol 150
staflex dop
truflex dop
vestinol ah
vinicizer 80
witcizer 312
Di-n-octyl o-phthalate
di(.alpha.-Ethylhexyl)phthalate
1,2-Benzenedicarboxylic acid bis(2-ethylhexyl)ester
Di(2-ethylhexyl)phthalat
Bis(2-ethylhexyl)phthalate solution
Di(2-ethylhexyl)phthalate solution
Phthalic acid bis(2-ethylhexyl)ester
Phthalic Acid Di(2-ethylhexyl)Ester
Phthalic acid,bis-2-ethylhexyl ester
1,2-benzenedicarboxylic acid,bis(2-ethylhexyl)ester
dehp(1,2-benzenedicarboxylic acid,bis(2-ethylhexyl)ester)
di(2-ethylhexyl)
di-2-ethylhexyl phthalate
di-2-ethylhexyl phthalate(dehp)
di-sec
di-sec octyl phthalate
dioctylphthalate
bis(2-ethylhexyl)1,2-benzenedicarboxylate
benzene-1,2-dicarboxylic acid bis(2-ethylhexyl)ester
phthalic acid bis-(2-ethyl-hexyl)ester
phthalic acid,bis(2-ethylhexyl)ester
性质描述: 无色透明液体,有特殊气味。熔点-55℃,沸点386.9℃,222-230℃(0.53kPa),相对密度0.986(20/4℃),折射率1.4852,闪点217℃,着火点241℃,粘度81.4mPa·s,蒸气压(200℃)176Pa。25℃时该品在水中溶解度< 0.01%,水在该品中的溶解度0.2%。溶于大多数有机溶剂和烃类,微溶于甘油、乙二醇。与大多数工业用树脂有良好的相容性。与醋酸纤维素、聚醋酸乙烯酯部分相容。该品是使用最广、产量最大的增塑剂,是邻苯二甲酸酯类增塑剂中最重要的品种。其次是邻苯二甲酸二丁酯(DBP,[87-74-2])、邻苯二甲酸二异癸酯(DIDP,[19269-67-1])、邻苯二甲酸二异辛酯(DIOP,[27554-26-3])。在增塑剂领域内,如果不加说明,“辛酯”习惯上是指2-乙基己酯。邻苯二甲酸二(2-乙基己基)酯(DOP)习惯上称为邻苯二甲酸二辛酯,它的异构体除邻苯二甲酸二异辛酯(DIOP)外,邻苯二甲酸二正辛酯(DnOP)也是实际应用的增塑剂,另外还有邻苯二甲酸二仲辛酯(DCP)。
生产方法: 增塑剂的用量很大,品种繁多。目前增塑剂生产技术的发展趋势,一方面是主增塑剂的连续化大生产,另一方面是特殊增塑剂的多品种、小批量的间歇生产。邻苯二甲酸酯类增塑剂的消费量约占增塑剂总量的80%,生产量很大,因而出现了以邻苯二甲酸二辛酯为中心的连续化大生产。邻苯二甲酸酯在工业上都是用苯酐与相应的醇在硫酸、对甲苯磺酸等酸性催化剂存在下酯化制得的,酸性催化剂的用量一般以苯酐计为0.2-0.5%。由苯酐与2-乙基己醇(异辛醇)在硫酸或钛酸酯、氧化亚锡、铝酸盐等非酸性催化剂催化下进行酯化反应,酯化液经中和、水洗、脱醇、脱色、压滤得成品。原料消耗定额:苯酐383kg/t、2-乙基己醇(95%)671kg/t、硫酸6kg/t、纯碱10kg/t。
用途: 该品是最广泛使用的增塑剂,除了乙酸纤维素、聚乙酸乙烯外,与绝大多数工业上使用的合成树脂和橡胶均有良好的相容性。本品具有良好的综合性能,混合性能好,增塑效率高,挥发性较低,低温柔软性较好,耐水抽出,电气性能高,耐热性和耐候性良好。该品作为一种主增塑剂,广泛应用于聚氯乙烯各种软质制品的加工,例如薄膜、薄板、人造革、电缆料和模塑品等。该品无毒,可用于与食物接触的包装材料,但由于易被脂肪抽出,故不宜用于脂肪性食品包装材料。还可用于硝基纤维素漆,使漆膜具有弹性的较高的抗张强度。在多种合成橡胶中,该品亦有良好的软化作用。另外,DOP还用作缩合剂、减磨剂、有机溶剂、
气相色谱固定液。
