Sorry can not type Chinese in office.
My 240 FS
AAS is working well. But I would like to know how to calibrate the instrument?
(just like HPLC system, every year we need system calibration on the pump, detector wavelength..)
I wonder that there maybe a detail method to calibrate the
AAS.
1.工作波段(Wavelength):190-900nm 2.波长精度(Wavelength accuracy):±0.25nm 3.分辨率(Resolution):Better than 0.3nm 4.基线稳定性(Baseline stability):0.005A/30m 5.光源(Light source):Hollow cathode lamp:0-20mA ,
So I would like to know how to calibrate the
AAS 240, to make my boss believe that before start testing, the
AAS instrument is good to go.
Thanks for any reply.
如何校正
原子吸收? 谢谢
实验室的头儿老是追我要:校正
原子吸收。
(不是每次测试的时候,采用标准溶液做出校正曲线,然后是待测样进样) 而是要求校正
原子吸收光谱仪,空心阴极灯的电流, 强度?灵敏度和信噪比? .工作波段(Wavelength):190-900nm, 波长精度(Wavelength accuracy)波长重复性, 谱带宽.
不知道如何下手? 请各位老师帮忙, 谢谢
以上文本借助<A href="http://www.inputking.com/"
