1.
Magnetic Behavior in Zinc Oxide Zigzag Nanoribbons
Andrés R. Botello-Méndez, Florentino López-Urías, Mauricio Terrones, and Humberto Terrones
Nano Lett., 8 (6), 1562–1565, 2008. 10.1021/nl072511q
http://pubs.acs.org/cgi-bin/abstract.cgi/nalefd/2008/8/i06/abs/nl072511q.html
2.
Ni/Ni3C Core–Shell Nanochains and Its Magnetic Properties: One-Step Synthesis at Low Temperature
Wei Zhou, Kun Zheng, Lin He, Rongming Wang, Lin Guo, Chinping Chen, Xiaodong Han, and Ze Zhang
Nano Lett., 8 (4), 1147–1152, 2008. 10.1021/nl073291j
http://pubs.acs.org/cgi-bin/abstract.cgi/nalefd/2008/8/i04/abs/nl073291j.html
3.
Fabrication of Nickel Hydroxide Microtubes with Micro- and Nano-Scale Composite Structure and Improving Electrochemical Performance
Feifei Tao, Mingyun Guan, Yiming Zhou, Li Zhang, Zheng Xu, and Jun Chen
Cryst. Growth Des., 8 (7), 2157–2162, 2008. 10.1021/cg7012123
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i07/abs/cg7012123.html
4.
Influence of Model Globular Proteins with Different Isoelectric Points on the Precipitation of Calcium Carbonate
A. Hernández-Hernández, A. B. Rodríguez-Navarro, J. Gómez-Morales, C. Jiménez-Lopez, Y. Nys, and J. M. García-Ruiz
Cryst. Growth Des., 8 (5), 1495–1502, 2008. 10.1021/cg070512q
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i05/abs/cg070512q.html
5.
Synthesis and Evolution of PbS Nanocrystals through a Surfactant-Assisted Solvothermal Route
Zhang, C.; Kang, Z.; Shen, E.; Wang, E.; Gao, L.; Luo, F.; Tian, C.; Wang, C.; Lan, Y.; Li, J.; Cao, X.
J. Phys. Chem. B.; (Article); 2006; 110(1); 184-189. DOI: 10.1021/jp053215+
http://pubs.acs.org/cgi-bin/abstract.cgi/jpcbfk/2006/110/i01/abs/jp053215+.html
6.
PbS-Doped Mesostructured Silica Films with High Optical Nonlinearity
Buso, D.; Falcaro, P.; Costacurta, S.; Guglielmi, M.; Martucci, A.; Innocenzi, P.; Malfatti, L.; Bello, V.; Mattei, G.; Sada, C.; Amenitsch, H.; Gerdova, I.; Hache, A.
Chem. Mater.; (Article); 2005; 17(20); 4965-4970. DOI: 10.1021/cm050850j
http://pubs.acs.org/cgi-bin/abstract.cgi/cmatex/2005/17/i20/abs/cm050850j.html
7.
Hierarchical, Star-Shaped PbS Crystals Formed by a Simple Solution Route
Ma, Y.; Qi, L.; Ma, J.; Cheng, H.
Cryst. Growth Des.; (Article); 2004; 4(2); 351-354. DOI: 10.1021/cg034174e
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2004/4/i02/abs/cg034174e.html
8.
Controlled Deposition of Oriented PbS Nanocrystals on Ultrathin Polydiacetylene Templates at the Air-Solution Interface
Berman, A.; Belman, N.; Golan, Y.
Langmuir; (Research Article); 2003; 19(26); 10962-10966. DOI: 10.1021/la035419s
http://pubs.acs.org/cgi-bin/abstract.cgi/langd5/2003/19/i26/abs/la035419s.html
