Uncertainty for the Analysis of 2,4-D Herbicide in Urine by
gc/ECD
Principle
Samples of urine are acidified and extracted using toluene which contains a surrogate
standard. The mixture is derivatised using diazomethane to form the methyl ester
Analysis Procedure
1. Take 1 mL of each urine to be analysed
2. To each tube add 1 mL of HCl/NaCl mixture.
3. Add 2 mL of nanograde toluene containing the surrogate.
4. Stopper the tube and shake for 5 sec, then mix for 1 hour on rotating mixer.
5. Centrifuge the samples for 15 minutes at 3500 rpm.
6. Transfer 1 mL of the toluene extract to a clean quick-fit tube, add sodium sulfate
(using a spatula) and shake to make sure that the Na2SO4 removes any water.
7. Add 1 mL of diazomethane reagent (see appendix for procedure on preparing
diazomethane reagent). Mix the solution and let stand in a fume cupboard.
8. Leave the tubes in the fume cupboard overnight to allow for the complete
decomposition of any unreacted diazomethane.
9. Transfer the toluene extract (~1 mL) to a
gc vial and analyse using an EC
detector.
Standards
Prepare separate stock standard solutions (0.1mg/ml) as follows:
1. Weigh accurately about 1.000-2.000mg of each of the standard 2,4-D, into a 10ml
volumetric flask and make up to volume with methanol.
2. Prepare composite spiked urine standards as follows:
