原文由 sgxhappy(sgxhappy) 发表:
看看 美国Aspex 怎么样,如果可以,可以联系我。s61396239@126.com
Particle Detection Range | 30nm to 5mm |
Detectors | SED, Quad BSED, SDD EDX |
Accelerating Voltage | 0.2 to 25 KeV Continuous |
Stage Movement | 80mm x 100mm |
Vacuum system | High Vac and Variable Pressure |
Imaging Resolution | 7nm |
Lightest Element Detection | Boron |
EDX Resolution | 135 eV |
Sizing Algorithms Available | RCA and CFA |
FDA Compliance Level | cGMP |
FDA Compliance Status | Validated |
Data Security | 21 CFR part 11 Compliant* |
