主题:【求助】求助氟虫胺的检测方法!
浏览0 回复2 电梯直达
leleljl
各位大侠帮帮忙!我近期要检测氟虫胺,可手上没有它的检测方法!谁有它的GC或HPLC的方法,请告诉我一下吧!谢谢了!
我在故我思
A rapid quantitative method for the analysis of sulfluramid and its isomers in ant bait by capillary column gas chromatography
Jairo K. Bastos,et al;
Abstract
Sulfluramid (N-Ethylperfluorooctane sulfonamide) is a highly effective insecticide for controlling ants. It is usually incorporated into orange pellets at a concentration of 0.3%, in combination with 4 to 6% soybean oil. The objective of the present study was to develop a capillary gas chromatography method for the quantitative analysis of sulfluramid and its isomers in orange pellet baits with the addition of 1,2,4,5-tetramethylbenzene as the internal standard. The proposed method proved to be rapid and reliable for the analysis of sulfluramid and its isomers in both raw material and baits. The experimental protocol, the conditions, and the equipment for analysis, as well as the recovery studies, are presented and discussed.
  http://www3.interscience.wiley.com/journal/84502201/abstract?CRETRY=1&SRETRY=0
leleljl
