化学品安全技术说明书
Material Safety Data Sheet
DIMETHYL FUMARATE, 99%
Section 1 - Chemical Product and Company Identification
MSDS Name: DIMETHYL FUMARATE, 99%
Catalog Numbers: 22218-0000, 22218-0250, 22218-1000
Synonyms:
Company Identification: Acros Organics BVBA
Janssen Pharmaceuticalaan 3a
2440 Geel, Belgium
Company Identification: (USA) Acros Organics
One Reagent Lane
Fair Lawn, NJ 07410
For information in the US, call: 800-ACROS-01
For information in Europe, call: +32 14 57 52 11
Emergency Number, Europe: +32 14 57 52 99
Emergency Number US: 201-796-7100
CHEMTREC Phone Number, US: 800-424-9300
CHEMTREC Phone Number, Europe: 703-527-3887
Section 2 - Composition, Information on Ingredients
CAS# Chemical Name: % EINECS#
624-49-7 DIMETHYL FUMARATE 99% 210-849-0
Hazard Symbols: XN
Risk Phrases: 21 36/37/38
Section 3 - Hazards Identification
EMERGENCY OVERVIEW
Harmful in contact with skin. Irritating to eyes, respiratory system and skin.
Potential Health Effects
Eye: Causes eye irritation.
Skin: Causes skin irritation. Harmful if absorbed through the skin.
Ingestion: May cause irritation of the digestive tract. May be harmful if swallowed.
Inhalation: Causes respiratory tract irritation. May be harmful if inhaled.
Chronic:
Section 4 - First Aid Measures
Eyes: Flush eyes with plenty of water for at least 15 minutes, occasionally lifting the upper and lower eyelids. Get medical aid.
Skin: Get medical aid. Flush skin with plenty of water for at least 15 minutes while removing contaminated clothing and shoes.
Ingestion: Get medical aid. Wash mouth out with water.
Inhalation: Remove from exposure and move to fresh air immediately.
Notes to Physician:
Section 5 - Fire Fighting Measures
General Information: As in any fire, wear a self-contained breathing apparatus in pressure-demand, MSHA/NIOSH (approved or equivalent), and full protective gear.
Extinguishing Media: Use agent most appropriate to extinguish fire.
Section 6 - Accidental Release Measures
General Information: Use proper personal protective equipment as indicated in Section 8.
Spills/Leaks: Vacuum or sweep up material and place into a suitable disposal container.
Section 7 - Handling and Storage
Handling: Avoid breathing dust, vapor, mist, or gas. Avoid contact with skin and eyes.
Storage: Store in a cool, dry place. Store in a tightly closed container.
Section 8 - Exposure Controls, Personal Protection
Engineering Controls:
Use adequate ventilation to keep airborne concentrations low.
Exposure Limits
CAS# 624-49-7:
Personal Protective Equipment
Eyes: Wear chemical splash goggles.
Skin: Wear chemical splash goggles.
Clothing: Wear appropriate protective clothing to minimize contact with skin.
Respirators: Wear a NIOSH/MSHA or European Standard EN 149 approved full-facepiece airline respirator in the positive pressure mode with emergency escape provisions.
Section 9 - Physical and Chemical Properties
Physical State: Crystals
Color: white
Odor: Not available
pH: Not available
Vapor Pressure: Not available
Viscosity: Not available
Boiling Point: 192 - 193 deg C @ 760 mmHg
Freezing/Melting Point: 102.00 - 105.00 deg C
Autoignition Temperature: Not available
Flash Point: Not available
Explosion Limits: Lower: Not available
Explosion Limits: Upper: Not available
Decomposition Temperature: Not available
Solubility in water: Not available
Specific Gravity/Density:
Molecular Formula: C6H8O4
Molecular Weight: 144.13
Section 10 - Stability and Reactivity
Chemical Stability: Stable under normal temperatures and pressures.
Conditions to Avoid: Incompatible materials.
Incompatibilities with Other Materials Incompatible materials, reducing agents, acids, bases.
Hazardous Decomposition Products Carbon monoxide, carbon dioxide.
Hazardous Polymerization Has not been reported.
Section 11 - Toxicological Information
RTECS#: CAS# 624-49-7: EM6125000
LD50/LC50: RTECS:
CAS# 624-49-7: Draize test, rabbit, eye: 250 ug/24H Severe;
Draize test, rabbit, skin: 20 mg/24H Moderate;
Oral, rat: LD50 = 2240 mg/kg;
Skin, rabbit: LD50 = 1250 mg/kg;
Carcinogenicity: DIMETHYL FUMARATE - Not listed as a carcinogen by ACGIH, IARC, NTP, or CA Prop 65.
Other: See actual entry in RTECS for complete information. The toxicological properties have not been fully investigated.
Section 12 - Ecological Information
Not available Section 13 - Disposal Considerations
Dispose of in a manner consistent with federal, state, and local regulations.
Section 14 - Transport Information
IATA IMO RID/ADR
Shipping Name: Not available Not available Not available
Hazard Class:
UN Number:
Packing Group:
Section 15 - Regulatory Information
European/International Regulations
European Labeling in Accordance with EC Directives
Hazard Symbols: XN
Risk Phrases:
R 21 Harmful in contact with skin.
R 36/37/38 Irritating to eyes, respiratory system and skin.
Safety Phrases:
S 36/37/39 Wear suitable protective clothing, gloves and eye/face protection.
WGK (Water Danger/Protection)
CAS# 624-49-7: Not available
Canada
CAS# 624-49-7 is listed on Canada's DSL List
US Federal
TSCA
CAS# 624-49-7 is listed on the TSCA Inventory.
Section 16 - Other Information
MSDS Creation Date: 7/16/1996
Revision #0 Date Original.
The information above is believed to be accurate and represents the best information currently available to us. However, we make no warranty of merchantibility or any other warranty, express or implied, with respect to such information, and we assume no liability resulting from its use. Users should make their own investigations to determine the suitability of the information for their particular purposes. In no event shall the company be liable for any claims, losses, or damages of any third party or for lost profits or any special, indirect, incidental, consequential, or exemplary damages howsoever arising, even if the company has been advised of the possibility of such damages.
附件的两个不是这个,是另外一个公司的中英文。
富马酸二甲酯 MSDS 中文版
富马酸二甲酯 MSDS英文版
