主题:【分享】ASTM 标准E系列514-598
浏览0 回复5 电梯直达
hunghe
该帖子已被zhozhozho设置为精华;
ASTM 标准E系列514-598
hunghe
hunghe
hunghe
czq8
目录如下
    ASTM E514-04Standard Test Method for Water Penetration and Leakage Through Masonry1.PDF [92.53KB]
    ASTM E515-95(Reapproved 2000)Standard Test Method for Leaks Using Bubble Emission Techniques1.PDF [37.91KB]
    ASTM E516-95a(Reapproved 2000)Standard Practice for Testing Thermal Conductivity Detectors Used in Gas Chromatography1.PDF [94.22KB]
    ASTM E517-00Standard Test Method for Plastic Strain Ratio r for Sheet Metal.PDF [85.09KB]
    ASTM E518-03Standard Test Method for Flexural Bond Strength of Masonry1.PDF [328.85KB]
    ASTM E519-02Standard Test Method for Diagonal Tension (Shear) in Masonry Assemblages1.PDF [358.09KB]
    ASTM E520-98(Reapproved 2003)Standard Practice for Describing Photomultiplier Detectors in Emission and Absorption Spectrometry1.PDF [70.80KB]
    ASTM E521-96(Reapproved 2003)Standard Practice for Neutron Radiation Damage Simulation by Charged-Particle Irradiation1.PDF [210.83KB]
    ASTM E523-02Standard Test Method for Measuring Fast-Neutron Reaction Rates by Radioactivation of Copper1.PDF [42.86KB]
    ASTM E524-88(Reapproved 2000)Standard Specification for Standard Smooth Tire for Pavement Skid-Resistance Tests1.PDF [46.03KB]
    ASTM E526-97(Reapproved 2002)Standard Test Method for Measuring Fast-Neutron Reaction Rates by Radioactivation of Titanium1.PDF [27.81KB]
    ASTM E527-83(Reapproved 2003)Standard Practice for Numbering Metals and Alloys (UNS)1.PDF [108.74KB]
    ASTM E529-04Standard Guide for Conducting Flexural Tests on Beams and Girders for Building Construction1.PDF [28.46KB]
    ASTM E531-76(Reapproved 2001)Standard Practice for Surveillance Testing of High-Temperature Nuclear Component Materials1.PDF [48.43KB]
    ASTM E534-98(Reapproved 2003)Standard Test Method for Chemical Analysis of Sodium Chloride1.PDF [52.91KB]
    ASTM E536-98Standard Test Method for Chemical Analysis of Zinc and Zinc Alloys1.PDF [57.37KB]
    ASTM E537-02Standard Test Method for The Thermal Stability Of Chemicals By Differential Scanning Calorimetry1.PDF [168.60KB]
    ASTM E538-98(Reapproved 2003)e1Standard Test Method for Mercury in Caustic Soda (Sodium Hydroxide) and Caustic Potash (Potassium Hydroxide)1.PDF [66.86KB]
    ASTM E539-02Standard Test Method for X-Ray Emission Spectrometric Analysis of 6AI-4V Titanium Alloy1.PDF [49.26KB]
    ASTM E541-01Standard Specification for Agencies Engaged in System Analysis and Compliance Assurance for Manufactured Building1.PDF [54.38KB]
    ASTM E542-01Standard Practice for Calibration of Laboratory Volumetric Apparatus1.PDF [73.83KB]
    ASTM E543-04Standard Practice for Agencies Performing Nondestructive Testing1.PDF [79.13KB]
    ASTM E544-99Standard Practice for Referencing Suprathreshold Odor Intensity1.PDF [106.48KB]
    ASTM E545-99Standard Test Method for Determining Image Quality in Direct Thermal Neutron Radiographic Examination1.PDF [42.78KB]
    ASTM E546-88(Reapproved 1999)e1Standard Test Method for Frost Point of Sealed Insulating Glass Units1.PDF [109.73KB]
    ASTM E547-00Standard Test Method for Water Penetration of Exterior Windows, Skylights, Doors,and Curtain Walls by Cyclic Static Air Pressure Difference1.PDF [60.31KB]
    ASTM E549-87(Reapproved 2002)Standard Guide for Preparing Field Sprayer Calibration Procedures1.PDF [26.39KB]
    ASTM E550-87(Reapproved 2002)Standard Guide for Preparing Granular Pesticide Ground Applicator Calibration Procedures1.PDF [22.47KB]
czq8
ASTM E556-95(Reapproved 2000)Standard Test Method for Calibrating a Wheel Force or Torque Transducer Using a Calibration Platform (User Level)1.PDF [32.75KB]
    ASTM E557-00Standard Guide for The Installation of Operable Partitions1.PDF [113.28KB]
    ASTM E560-01Standard Practice for Extrapolating Reactor Vessel Surveillance Dosimetry Results, E 706(IC)1.PDF [66.02KB]
    ASTM E561-98Standard Practice for R-Curve Determination1.PDF [207.14KB]
    ASTM E562-02Standard Test Method for Determining Volume Fraction by Systematic Manual Point Count1.PDF [66.76KB]
    ASTM E563-02Standard Practice for Preparation and Use of an Ice-Point Bath as a Reference Temperature 1.PDF [33.43KB]
    ASTM E564-00e1Standard Practice for Static Load Test for Shear Resistance of Framed Walls for Buildings1.PDF [107.16KB]
    ASTM E566-99Standard Practice for Electromagnetic (Eddy-Current) Sorting of Ferrous Metals1.PDF [40.25KB]
    ASTM E569-02Standard Practice for Acoustic Emission Monitoring of Structures During Controlled Stimulation1.PDF [41.84KB]
    ASTM E570-97(Reapproved 2004)e1Standard Practice for Flux Leakage Examination of Ferromagnetic Steel Tubular Products1.PDF [82.56KB]
    ASTM E571-98(Reapproved 2003)e1Standard Practice for Electromagnetic (Eddy-Current) Examination of Nickel and Nickel Alloy Tubular Products1.PDF [53.62KB]
    ASTM E572-02Standard Test Method for Analysis of Stainless and Alloy Steels by X-ray Fluorescence Spectrometry1.PDF [56.09KB]
    ASTM E573-01Standard Practice for Internal Reflection Spectroscopy1.PDF [271.16KB]
    ASTM E574-00Standard Specification for Duplex, Base Metal Thermocouple Wire With Glass Fiber or Silica Fiber Insulation1.PDF [30.37KB]
    ASTM E575-99Standard Practice for Reporting Data from Structural Tests of Building Constructions, Elements, Connections, and Assemblies1.PDF [22.42KB]
    ASTM E576-88(Reapproved 1999)e1Standard Test Method for Frost Point of Sealed Insulating Glass Units in the Vertical Position1.PDF [208.89KB]
    ASTM E577-85(Reapproved 2002)Standard Guide for Dimensional Coordination of Rectilinear Building Parts and Systems1.PDF [74.84KB]
    ASTM E578-01Standard Test Method for Linearity of Fluorescence Measuring Systems1.PDF [28.62KB]
    ASTM E579-04Standard Test Method for Limit of Detection of Fluorescence of Quinine Sulfate in Solution1.PDF [32.32KB]
    ASTM E580-02Standard Practice for Application of Ceiling Suspension Systems for Acoustical Tile and Lay-in Panels in Areas Requiring Seismic Restraint1.PDF [92.10KB]
    ASTM E581-76(Reapproved 1996)Standard Test Method for Chemical Analysis of Manganese-Copper Alloys1.PDF [46.34KB]
    ASTM E582-88(Reapproved 1999)Standard Test Method for Minimum Ignition Energy and Quenching Distance in Gaseous Mixtures1.PDF [92.74KB]
    ASTM E585-04Standard Specification for Compacted Mineral-Insulated, Metal-Sheathed, Base Metal Thermocouple Cable1.PDF [60.10KB]
    ASTM E587-00Standard Practice for Ultrasonic Angle-Beam Examination by the Contact Method1.PDF [135.11KB]
    ASTM E588-03Standard Practice for Detection of Large Inclusions in Bearing Quality Steel by the Ultrasonic Method1.PDF [76.22KB]
    ASTM E592-9Standard Guide to Obtainable ASTM Equivalent Penetrameter Sensitivity for....PDF [88.99KB]
    ASTM E594-96(Reapproved 2001)Standard Practice for Testing Flame Ionization Detectors Used in Gas or Supercritical Fluid Chromatography1.PDF [64.82KB]
    ASTM E595-93(Reapproved 2003)e1Standard Test Method for Total Mass Loss and Collected Volatile Condensable.PDF [108.92KB]
    ASTM E596-96(Reapproved 2002)e1Standard Test Method for Laboratory Measurement of Noise Reduction of Sound-Isolating Enclosures1.PDF [69.96KB]
    ASTM E598-96(Reapproved 2002)Standard Test Method for Measuring Extreme Heat-Transfer Rates from High-Energy Environments Using a Transient, Null-Point Calorimeter1.PDF [186.87KB]
