主题:【讨论】有谁知道XRD定量分析软件 SIROQUANT 吗
浏览0 回复3 电梯直达
s605zb
Siroquant is a unique software package used for the quantification of crystalline compounds. Importantly Siroquant does not require specialist crystallographic knowledge to obtain reliable mineral/phase analysis
Siroquant is currently being used by many industrial, scientific and academic organisations around the world. It has a logical user friendly Windows interface including extensive on-line help.  The system is equally useful for industrial and research applications.
Siroquant is compatible with Microsoft Windows NT, 2000, XP and Vista.
A comprehensive database contains over 1800 common minerals and compounds.
http://www.sietronics.com.au/siroquant.html
您可能想找: X射线衍射仪(XRD) 询底价
逆水寒
beidou3714
sir和quanto好像是在意大利的一个研究所网页上就可以下载,但是这些软件只提供给研究所和大学等科研机构,所以你要是使用的话就要去网站上下载一个电子表格,然后把你的信息填上去给他传真过去,审核之后就可以在网站上下载了,这些软件都是涉及版权的,如果没有申请通过的话千万不要在杂志上公开发表,否则会死的很惨的!
你要是想用的话直接在google里搜,应该可以找到他的网址
aoei
