主题:原子吸收光谱各元素常用谱线
浏览0 回复9 电梯直达
100101
元素
灵敏线
次灵敏线
元素
灵敏线
次灵敏线
Ag
328.068
338.289
Er
400.797
415.110
381.033
393.702
397.360
Al
309.271
308.216
309.284
394.403
396153
Eu
459.403
311.143
321.057
462.722
466.188
As
188.990
193.696
197.197
Fe
248.327
208.412
248.637
252.285
302.064
Au
242.795
267.595
274.826
312.278
Ga
287.424
294.418
403.298
417.206
B
249.678
249.773
Gd
368.413
371.357
371.748
378.305
407.870
Ba
553.548
270.263
307.158
350.111
388.933
Ge
265.158
259.254
270.963
275.459
Be
234.861
313.042
313.107
Hf
307.288
286.637
290.441
302.053
377.764
Bi
223.061
206.170
222.825
227.658
306.772
Hg
184.957*
253.652
Ca
422.673
239.356
272.164
393.367
396.847
Ho
410.384
405.393
410.109
412.716
417.323
Co
240.7.25
242.4.93
304.4.00
352.6.85
252.1.36
In
303.936
256.015
325.609
410.476
451.132
Cr
357.869
359.349
360.533
425.437
427.480
Ir
263.971
263.942
266.479
284.972
237.277
Cs
852.110
894.350
455.536
459.316
K
766.491
404.414
404.720
769.898
Cu
324.754
216.509
217.894
218.172
327.396
La
550.134
357.443
392.756
407.918
494.977
Dy
421.172
419.485
404.599
394.541
394.470
Li
670.784
274.120
323.261
Mg
385.213
279.553
202.580
230.270
Lu
335.956
308.147
328.174
331.211
356.784
Mn
279.482
222.183
280.106
403.307
403.449
Se
196.090
203.985
206.219
207.479
Mo
313.259
317.035
319.400
386.411
390.296
Si
251.612
250.690
251.433
252.412
252.852
Na
588.995
330.232
330.299
589.592
Sm
429.674
476.027
520.059
528.291
Nb
334.371
334.906
358.027
407.973
412.381
Sn
224.605
235.443
286.333
Nd
463.424
468.35
489.693
492.453
562.054
Sr
460.733
242.810
256.947
293.183
407.771
Ni
232.003
231.096
231.10
233.749
323.226
Ta
271.467
255.943
264.747
277.588
Os
290.906
305.866
790.10
Tb
432.647
390.135
431.885
433.845
Pb
216.999
202.202
205.327
283.306
Te
214.275
225.904
238.576
Pd
247.642
244.791
276.309
340.458
Ti
364.268
319.990
363.546
365.350
399.864
Pr
495.136
491.403
504.553
513.342
Tl
276.787
231.598
237.969
258.014
377.572
Pt
265.945
214.423
248.717
283.030
306.471
U
351.463
355.082
358.488
394.382
415.400
Rb
789.023
420.185
421.556
794.760
V
318.398
382.856
318.540
437.924
Re
346.046
345.188
242.836
346.473
W
255.135
265.654
268.141
294.740
Rh
343.489
339.685
350.252
369.236
370.091
Y
407.738
410.238
412.831
414.285
Ru
349.894
372.803
379.940
Yb
398.799
266.449
267.198
346.437
Sb
217.581
206.833
212.739
231.147
Zn
213.856
202.551
206.191
307.590
Sc
391.181
326.991
290.749
402.040
402.369
Zr
360.119
301.175
302.952
354.768
带有*号者为真空紫外线,通常条件下不能应用
您可能想找: 原子吸收光谱(AAS) 询底价
wishfly1979
lido
原文由 wishfly1979 发表:
辛苦了,但好像参考价值不大
对于混标配制有参考意义啊
shine_806
ptcdc
wave41392003
popo
qinchem
qinchem
liurun1979
