主题:【求助】油墨国家检验标准
浏览0 回复3 电梯直达
397519967
求油墨国标啊,希望是全部的。。。。。。。谁可帮帮我,跪谢
我在故我思
1 GB/T 15962-2008 油墨术语 Glossary of printing ink terms 现行 2009-05-01实施,代替GB/T 15962-1995
2 GB/T 18724-2008 印刷技术 印刷品与印刷油墨耐各种试剂性的测定 Graphic technology - Prints and printing inks - Assessment of resistance to various agents 现行 2009-09-01实施,代替GB/T 18724-2002
3 GB/T 22770-2008 印刷技术 用落棒式粘度计测定浆状油墨和连接料的流变性 Graphic technology - Determination of rheological properties of paste inks and vehicles by the falling rod viscometer 现行 2009-09-01实施
4 GB/T 22771-2008 印刷技术 印刷品与印刷油墨用滤光氙弧灯评定耐光性 Graphic technology - Prints and printing inks - Assessment of light fastness using filtered xenon arc light 现行 2009-09-01实施
5 GB/T 6753.1-2007 色漆、清漆和印刷油墨 研磨细度的测定 Paints 、varnishes and printing inks - Determination of fineness of grind 现行 2008-04-01实施,代替GB/T 6753.1-1986
6 GB/T 12911-1991 纸和纸板油墨吸收性的测定法 Paper and board--Determination of the ink absor-bency 现行 1992-03-01实施
7 GB/T 13217.1-2009 液体油墨颜色检验方法 Test method for colour of liquid ink 现行 2009-11-01实施,代替GB/T 13217.1-1991
8 GB/T 13217.2-2009 液体油墨光泽检验方法 Test method for gloss of liquid ink 现行 2009-11-01实施
9 GB/T 13217.3-2008 液体油墨细度检验方法 Test method for fineness of grind of liquid ink 现行 2009-09-01实施
10 GB/T 13217.4-2008 液体油墨粘度检验方法 Test method for viscosity of liquid ink 现行 2009-09-01实施
11 GB/T 13217.5-2008 液体油墨初干性检验方法 Test method for initial dryness of liquid ink 现行 2009-09-01实施
12 GB/T 13217.6-2008 液体油墨着色力检验方法 Test method for relative tinting strength of liquid ink 现行 2009-09-01实施
13 GB/T 13217.7-2009 液体油墨附着牢度检验方法 Test method for adhesion to substrate of liquid ink with tape 现行 2009-11-01实施
14 GB/T 13217.8-2009 液体油墨抗粘连检验方法 Test method for blocking resistance of liquid ink 现行 2009-11-01实施
15 GB/T 14624.1-2009 胶印油墨颜色检验方法 Test method for colour of offset ink 现行 2009-11-01实施,代替GB/T 14624.1-1993
16 GB/T 14624.2-2008 胶印油墨着色力检验方法 Test method for colour strength of offset ink 现行 2009-09-01实施
17 GB/T 14624.3-2008 胶印油墨流动度检验方法 Test method for fluidity of offset ink 现行 2009-09-01实施
18 GB/T 14624.4-2008 胶印油墨结膜干燥检验方法 Test method for drying time of film formation of offset ink 现行 2009-09-01实施
19 GB/T 14624.5-1993 油墨粘性检验方法 Test method for tack of printing inks 现行 1994-05-01实施
20 GB/T 14624.6-1993 油墨粘性增值检验方法 Test method for increase in value of tack of printing inks 现行 1994-05-01实施
21 GB/T 17001.1-1997 防伪油墨 第一部分:紫外激发荧光油墨(胶版、凸版印刷)技术条件 Anti-counterfeiting ink--Part 1:Technical requirement of ultraviolet fluorescent ink 现行 1998-05-01实施
22 GB/T 17934.3-2003 印刷技术 网目调分色片、样张和印刷成品的加工过程控制 第3部分: 新闻纸的冷固型油墨胶印 Graphic technology--Process control for the manufacture of half-tone colour separations,proofs and production prints--Part 3: Coldset offsetlithography on newsprints 现行 2003-12-01实施,代替GB/T 14705-1993
23 GB/T 18723-2002 印刷技术 用黏性仪测定浆状油墨和连接料的黏性 Graphic technology--Determination of tack of paste inks and vehicles by a rotary tackmeter 现行 2003-01-01实施
24 GB/T 18751-2002 磁性防伪油墨 Magnetic anti-counterfeiting printing ink 现行 2003-01-01实施
25 GB/T 18752-2002 热敏变色防伪油墨 Heating color variable printing ink 现行 2003-01-01实施
26 GB/T 18753-2002 日光激发变色防伪油墨 Sunlight excitation color variable printing ink 现行 2003-01-01实施
27 GB/T 18754-2002 凹版印刷紫外激发荧光防伪油墨 UV-excitation fluorecent anti-counterfeiting intaglio printing ink 现行 2003-01-01实施
28 GB/T 20216-2006 有效残余油墨的测定 Determination of effective residual ink 现行 2006-10-01实施
29 GB/T 22467.2-2008 防伪材料通用技术条件 第2部分:防伪油墨和印油
你好!国标有这些,楼主都需要吗?
397519967
这些国际合适柔版,凸版,凹版,平版等的不同类型的油墨检验吗??
还有,请问有油墨通用的原材料的检验标准吗?
如果想要这些标准,请问在那里有得下啊?是免费吗?
谢谢
阳线
原文由 397519967(397519967) 发表:
谢谢
需要业内人士才了解,你可以直接对照这些标准的具体内容。
请用标准号的数字作关键词,在论坛附件http://www.instrument.com.cn/bbs/AttachmentList.asp和资料中心http://www.instrument.com.cn/download/查找,没有的再发求助帖,论坛附件免积分,资料中心下载需要1至10积分,所有的这些下载均免费。
