原文由 闲鹤野云(ruojun) 发表:
A gas chromatograph with a capillary column coupled to a mass spectrometric detector (electron ionisation,EI) is used for the analysis.
本分析使用了具有偶合质谱检测器(电离子化,EI)毛细管柱的气相色谱(气质联仪)。
见笑
There is no doubt that one of the translations of couple is 偶合.
But in structural engineering, the connection of two reinforcing bars can be by means of a coupler. Would it be possible that “coupled to” means connected to? (I have no knowledge about the gas chromatograph and mass spectrometric detector)
