我把楼主的图谱放 了出来,怎么还有乱码呢?
纯水2图谱Printed by: 761
ICIdent: up-water-1224-2
Analysis from: 2009-12-24 11:13:40
File: tc241113.chw Last save: 2009-12-24 11:31:38
Method: ASUPP4_250.mtw Last save: 2009-12-24 9:52:58
Run operator: 761
ICAnalysis number: 271
SAMPLE:
Vial number: 0
Volume: 20.0 礚
Dilution: 1.00
Amount: 1.0000
COLUMN: METROSEP A SUPP 4 - 250 (6.1006.430)
Size: 4.0 x 250 mm
Number:
Part.size: 9.0 祄
ELUENT: 1.8 mmol/l Na2CO3 / 1.7 mmol/L NaHCO3
Flow: 1.00 mL/min
Temperature: 20.0癈
Pressure: 9.1 MPa
Quantitation method: Custom
No Retention Height Area Conc. Name
min uS/cm uS/cm*sec mg/L
1 4.10 0.01 0.885 0.000
2 4.59 0.00 0.006 0.000
3 4.99 0.01 0.201 0.000
4 5.54 0.02 0.417 0.103 Cl
5 6.46 0.00 0.010 0.000
6 7.39 0.00 0.079 0.109 Br
7 8.06 0.00 0.011 0.000
8 8.45 0.00 0.001 0.000
9 9.56 0.00 0.020 0.000
Page 2; tc241113.chw; 24/12/2009 13:45:02
10 10.38 0.00 0.124 0.000
11 11.12 0.00 0.004 0.000
12 12.61 0.00 0.011 0.000
13 15.14 0.00 0.188 0.000
14 16.42 0.00 0.007 0.000
15 16.91 0.00 0.002 0.000
_____________________________________________
15 18.00 0.05 1.966 0.213
This report has been created by
IC Net
METROHM LTD
