原文报道:
The European Food Safety Authority (EFSA) has completed the first ever review of the safety of 11 smoke flavourings used in the European Union. Based on EFSA’s work, the European Commission will establish a list of smoke flavouring products authorised for use in foods.
Klaus-Dieter Jany, the chair of EFSA’s expert Panel on flavourings (CEF Panel) said: “The Panel based its conclusions on the limited data which are currently available as well as conservative – or cautious – intake estimates. The Panel expressed safety concerns for several smoke flavourings where intake levels could be relatively close to the levels which may cause negative health effects. However, this does not necessarily mean that people consuming these products will be at risk as, in order to be on the safe side, the consumption estimates deliberately over-estimate intake levels.”
To assess the safety of these smoke flavourings, the CEF Panel asked manufacturers for data on the composition and toxicity of their products as well as details on their intended uses and use levels. Based on this information, the Panel determined the highest intake level at which each product was shown not to cause adverse health effects in animals[1]. This level was then compared to estimated intake levels for humans in order to determine “margins of safety” for each product.
Out of the 11 smoke flavourings evaluated by the Panel, experts found that the margins of safety for two of the products[2] were large enough not to give rise to safety concerns when considering the uses and use levels specified by the manufacturers. For eight others[3], the smaller margins of safety did give rise to safety concerns and for one of those smoke flavourings[4] the Panel could not rule out concerns regarding possible genotoxicity (damage to the genetic material of cells) given the available data. The Panel could not assess the safety of one further smoke flavouring[5] due to the lack of adequate data available.
Smoke flavourings are products which can be added to certain foods – including meat, fish or cheeses – to give them a “smoked” flavour, as an alternative to traditional smoking. They can also be used as flavourings in other foods such as soups, sauces, drinks and confectionery. All of the smoke flavourings which have now been assessed by EFSA are currently, or have previously been, on the market in the EU.
