Automatic Weather Station is a set of air-to-line automatic analytical instruments as the core, use of modern sensor technology, automatic measurement, automatic control technology, computer application technology and related proprietary analysis software, and communications network consisting of a comprehensive on-line automatic monitoring system. However, due to atmospheric automatic monitoring stations can only rely on automatic monitoring equipment 24 hours non-stop operation analysis of obtained data, how to ensure the normal operation of automatic monitoring equipment automatically stops the atmosphere daily work priorities. In this paper, I stood standing in the atmosphere to run automatically appear in some of the problems, access to information,
The actual situation and come to some of the leading atmospheric automatic weather station is not running properly causes and solutions
这个是我用软件翻译的,不知道对不对
该帖子作者被版主
hyheying加 3积分,
2经验,加分理由:有效求助
