原文由 learner1999 发表:
Please indicate the registration number of your manuscript if it was submitted earlier and the present manuscript is corrected version. Otherwise, please clearly indicate that you would like to submit it to the journal for consideration for publishing within the Journal of Chemistry of Natural Compounds.
原文由 zhaoliwei 发表:原文由 learner1999 发表:
如果该文章是以前所投文章的修改稿,请注明文章的注册号。否则,请清楚表明你希望将该文章投至Journal of Chemistry of Natural Compounds发表。
