主题:【求助】最低检测限
浏览0 回复5 电梯直达
yukai234589
大家的最低检测限是怎么具体算出来的
3倍基线噪音,具体怎么操作
johne0212
LoD and LoQ could be assessed by different approaches. From the following procedures, choose the one which is the most appropriate to the method to be validated:
1)    LoD and LoQ estimation by signal/noise ratio procedure (chromatographic and spectroscopic methods):
Parameter    Minimum requirement
Samples:    Spike one blank sample at 3 low concentration levels close to the expected LoD and LoQ (at least 3 concentration levels)
Number of replicates:    Analyze each spiked sample 3 times
2)    LoD and LoQ by standard deviation of the blank (gravimetric, photometric, enzymatic, titrimetric methods):
Samples:    1 blank sample (or 1 sample with a low amount of analyte)
Number of replicates:    At least 6 replicates
3)    LoQ by target performance characteristics (precision and/or recovery):
Samples:    Spike one blank sample at low concentration levels close to the expected LoQ (at least 3 concentration levels)
Number of replicates:    Analyze each spiked sample at least 3 times.
4)    LoQ corresponding to the lowest calibration point (lowest validated level)
海边
zhufangwei
ununy
最低浓度标样走10针,峰面积或者峰高的标准偏差的3倍代入回归公式,有时候不强制过原点截距为负可能算出来是负的...这个时候就是直接用的浓度的标准偏差的3倍,反正我是这么弄的....
1818
