主题:【分享】索谱隔水培养箱
suopuyiqi2010
用途概念:summary
      适用于医疗卫生,医药,生物,化学,农业科学等科研部门进行恒温培养必须的专业设备。
It is suitable for the scientific research departement in medica health,medicine,biology,chemistry,agriculture etc.and is an necessary specialized equimpent for thermostatic culture.
产品特点:features
培养箱水套采用不锈钢氩弧焊制作,经久耐用。
The incubator·s water-jacket,made of stainless stee by ar gon are welding, is very durable
    微机控温,高低水温报警及超温报警。
Temperature control by digitar display:when in-incubator temperature exceeds the perset value or when the water level in water level in water-jacket is too high or too low,an acoustooptie will sound automatically.
  不锈钢工作室,隔水式加热方式、温度均匀。
It adopts stainless steel working chamber and wate-jacket beating mode temperature is even in working cha-mber.
  采用硅橡胶密封及钢化玻璃双层门防泄露装置,观察方便。
Adopt silicon rubber sealing and toughened glass double-layer door with leakeage-proof device,being easy
to observe.
技术参数:Specifications
技术参数:
型号:GHP-9050
产品类型:微电脑普通型
电源电压:AC 220V±10%/50Hz±2%
加热方式:水套式Heating water
控温范围:室温+5-65
温度分辨率:0.1
温度波动度:±1
温度均匀度:±0.2~±0.5
输入功率:500w
内胆尺寸(mm):350*350*410载物托架:2块
该帖子作者被版主 后知后觉2积分, 2经验,加分理由:感谢分享
职业游民
