learner1999回复于2010/10/27
关键字 空气自动站;校零;数值偏低;报警
keywords: Atmosphere auto-monitoring station; Zero calibration ; Low value; Alarm
poorlittle回复于2010/10/27
Alternative :
校零 zero setting
报警 alert
数值偏低 : values lower than normal (expected)?
ja19840616回复于2010/12/06
应该是 Zero calibration 好点
数值偏低 之类的表述通常不出现在关键字中 values lower than normal 还不如 lower values 或 low values
影子回复于2010/12/06
赞成 ja19840616,校零用Zero calibration更专业一些
原文由 rock_rock(rock_rock) 发表:帮忙把名字还有关键词一起翻译好么。谢谢
Abstract:
Automatic air monitoring station provides real time monitoring data through 24 hours continuous analysis. To safeguard the correct functioning of automatic monitoring devices is therefore the most critical routine of automatic air monitoring station. To address the operational failure of automatic air monitoring station, cause analysis is provided for identifying resolutions.
