原文由 zhenyihong 发表:
Uncertainty evaluation on errors in displayed values of a transient-flow-rate measurement by Flow Integration Meters
正费了些脑细胞,把这事想了一下,结果竟然已经结贴了。我只好重开新贴。
有几点:
我不建议两个有修饰和被修饰关系的名词放在第三个名词前,那样很容易理解出很多意思;要用,就把词用连字符串起来;
瞬时-用精确的英文说,是“时间依赖的”,我这里用个比较生的TRANSIENT,看上去很快!;也像是画蛇添足;
整个这个所谓评估的逻辑关系。最终是不确定性评估,所以我把它放最前,然后是显示值的误差,BY什么流量计。积分不是Intergration,楼主有点没睡醒。而且,Flow Integration Meters似乎有点不地道。或许积分流量计更好。
最后说一句,我在学习,请别删我的贴。
原文由 zhenyihong 发表:
原文由 poorlittle 发表:原文由 zhenyihong 发表:
Because of the widely use of computer, many measurements can be “on-line” and “real time”. I am not sure whether 瞬时 implies real time measurement as I have no experience in using the flow meter.
I just used “flow meter”, “real time” and/or “transit time” as key words for searching with Google, and found that both “real-time” and “transit-time” were used in the websites regarding flow meters.
原文由 zhenyihong 发表:
yes, i agree that real-time cld be a better choice rather than transient which indicates the time span on 10-6 s or even less. on the other hand, "integration" is another trouble maker in the phrase. sucks.
原文由 zhenyihong 发表:
i also searched on google and found no "flow integration/ing meters" or other similar expression. that is why i think "integration" could be a trouble. anyway, it is the technical point we don't really need to pursue. however, the whole phrase is somewhat hard concerning to the logic.
Quoted from Google:
约有1,130,000项符合flow meter, integrating的查询结果
约有429项符合flow meter, integrating-type的查询结果
约有314项符合flow meter, integration-type的查询结果
How about “Uncertainty Evaluation of Error for the Real-time Flow Rate Measured by (an) Integrating-type Flow Meter”
or
“Evaluation of Uncertainty of Error of the Real-time Flow Rate Measured by Integrating-type Flow Meter”.
The second one seems too many “of”, but I don’t know why, I would prefer the second one.
