原文由 六星上将(angel1999) 发表:
标准号 BS EN 828-1998
英文标题 Adhesives - Wettability - Determination by measurement of contact angle and critical surface tension of solid surface
采用标准 EN 828-1997,IDT
都是高人,谢谢大家!
好像2010版的还没发布实施。
Standard Reference | EN 828:1997 |
Technical Body | CEN/TC 193 - Adhesives |
Status | Published |
DAV | 1997-10-22 |
DOA | 1998-01-31 |
DOP | 1998-04-30 |
DOW | 1998-04-30 |
Title | Adhesives - Wettability - Determination by measurement of contact angle and critical surface tension of solid surface |
Scope | This European standard specifies the determination of the ability of an adhesive to "wet" a solid surface by measuring the contact angle and determining the critical surface tension of wettability. It allows the prediction of what adhesive will wet which adherend. It may be used to characterize surfaces after priming, coating and bonding. |
Directive (citation in OJEU(1)) | - |
ICS(2) | 83.180 - Adhesives |
Definition of DAV, DOA, DOP and DOW(1) OJEU - Official Journal of the European Union
(2) ICS - International Classification for Standards
