原文由 chengjingbao(chengjingbao) 发表:
NOTE: “WARNING: actual selected gas is” followed by the gas currently selected is displayed if this gas is not the zero gas (SOV2 energized) when a re-zero is about to be performed or if it is not the span gas (SOV3 energized) when a re-span is about to be performed.
原文由 poorlittle(poorlittle) 发表:原文由 chengjingbao(chengjingbao) 发表:
注意:【警告:实际选择的气体是】这段文字后会显示当前选择的气体, if this gas is not the zero gas (SOV2 energized) when a re-zero is about to be performed or if it is not the span gas (SOV3 energized) when a re-span is about to be performed.
哈 强烈支持这个, 原来引号在前面 刚看到 ,这样就说的通了
原文由 ja19840616(ja19840616) 发表:原文由 poorlittle(poorlittle) 发表:原文由 chengjingbao(chengjingbao) 发表:
是否可以这样理解:在零位校前之前,如果这时不是零位气,零位气电磁阀SOV2打开,或者,在量程气校验之前,如果此时不是量程气,量程气电磁阀SOV3打开。
原文由 chengjingbao(chengjingbao) 发表:原文由 ja19840616(ja19840616) 发表:原文由 poorlittle(poorlittle) 发表:原文由 chengjingbao(chengjingbao) 发表:
应该就是这个意思了 ,应该是在零位校正或量程气校验得时候的提示或警示信息的意思
