It looks like your 南非工程师 not solid for this machine.
Basically, this x-ray tube is the same as the light at our home, if power on, the light should be on. X-ray power supply HV has many controls, including software doing judgment about all the parameters and physical controls listening to the software procedure. The key is to control the stability of electricity, for example, suppose now 40KV 30MA, if the control sensors find the true electricity 39.5KV 29.4MA, out of its limits, it will stop the procedure and send out the error message. "timeout" means waiting too long before stability says ok for next procedure. So for sure you can use the machine, those controls can help you to control automatically by designing, even the 南非工程师 cannot be sure everything ok or not.
该帖子作者被版主
albert800922加 4积分,
2经验,加分理由:鼓励讨论
