学校没数据库,哎,只能寻求各位的帮忙了,先谢谢了。文献情况如下:
Measurement of spatiotemporal phase statistics in turbulent air flow using high-speed digital holographic interferometry
Abstract
| Full Text: PDF 发布于 Applied Optics, Vol. 49 Issue 8, pp.1314-1322 (2010) 作者 Lycksam, Henrik; Sjödahl, Mikael; Gren, Per 摘要 We describe a method of measuring spatiotemporal (ST) structure and covariance functions of the phase fluctuations in a collimated light beam propagated through a region of...
Absolute surface metrology by differencing spatially shifted maps from a phase-shifting interferometer
Abstract
| Full Text: PDF 发布于 Optics Letters, Vol. 35 Issue 14, pp.2346-2348 (2010) 作者Bloemhof, E E 摘要Surface measurements of precision optics are commonly made with commercially available phase-shifting Fizeau interferometers that provide data relative to flat or spherical reference...
Entanglement-Enhanced Measurement of a Completely Unknown Phase
Abstract
| Full Text: PDF 发布于 Quantum Electronics and Laser Science Conference (QELS) 2010 paper: QThJ5 o OSA Technical Digest (CD) 作者Berry, Dominic W; Xiang, Guo-Yong; Higgins, Brendon L; Wiseman, Howard M; Pryde, Geoff J 摘要 We demonstrate a method for achieving phase measurements with accuracy beyond the standard quantum limit using entangled states. A sophisticated feedback scheme means that no initial... Image-Based Measurement of Phase Transfer Function
Abstract
| Full Text: PDF 发布于Digital Image Processing and Analysis (DIPA) 2010 paper: DMD1 OSA Technical Digest (CD) 作者 Bhakta, Vikrant R; Somayaji, Manjunath; Christensen, Marc P 摘要 A method for measuring the Phase Transfer Function (PTF) from a high-contrast edge image is proposed and the advantages of utilizing the knowledge of PTF in computational, sparse... Slope measurement of a phase object using a polarizing phase-shifting high-frequency Ronchi grating interferometer
Abstract
| Full Text: PDF
发布于 Applied Optics, Vol. 49 Issue 33, pp.6402-6408 (2010) 作者Toto-Arellano, Noel-Ivan; Martínez-García, Amalia; Rodríguez-Zurita, Gustavo; Rayas-Álvarez, Juan Antonio; Montes-Perez, Areli 摘要An interferometric method to measure the slope of phase objects is presented. The analysis was performed by implementing a polarizing phase-shifting cyclic shear interferometer.
有哪位大侠帮助下,先谢谢了,第一次发帖,情况紧急,晚上必须赶出来。没办法遵守规则,下次肯定遵守。
