Polymer paperSolution properties of poly(vinylidene fluoride): 1. Macromolecular characterization of soluble samples References and further reading may be available for this article. To view references and further reading you must purchase this article.
G. Lutringer*, a and G. WeillaaInstitut Charles Sadron (CRM-EAHP), Université L. Pasteur, 6 rue Boussingault, 67083 Strasbourg Cedex, France
Received 7 November 1989;
revised 22 February 1990;
accepted 27 April 1990.
Available online 16 April 2003.
AbstractDissolution in a range of solvents reveals two kinds of behaviour of poly(vinylidene fluoride) (PVDF): readily soluble samples (mostly suspension-polymerized) and partly gel-forming samples (mostly emulsion-polymerized). From molecular characterization of a number of industrial and laboratory samples of the first kind in solution in different solvents by light scattering, intrinsic viscosity and size exclusion chromatography, we derive unperturbed dimensions and χ parameters. Our results differ from previous measurements where light-scattering experiments were carried out in solvents with very low
and/or on less-soluble (second-kind) PVDF, where microgel formation cannot be avoided.
Keywords: poly(vinylidene fluoride); conformation; thermodynamic interaction; light scattering; intrinsic viscosity; size exclusion chromatography
* Present address: Ciba-Geigy, Basel, Switzerland
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TXW-48CPKVF-18D&_user=10&_coverDate=12%2F31%2F1991&_rdoc=1&_fmt=high&_orig=gateway&_origin=gateway&_sort=d&_docanchor=&view=c&_searchStrId=1720109531&_rerunOrigin=google&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=43ee54265c69b756cb1b164fce7977cc&searchtype=a
