20-0532这张卡片没有发布I/Ic值
相同的物质的其他卡片有的发布了I/Ic值的,仅供参考:
PDF# QM Formula name system I/Ic
04-002-5014 Blank Fe Si2 Iron Silicon Orthorhombic 1.49
04-003-3365 Prototyping Fe Si2 Iron Silicon Orthorhombic 1.51
04-003-3829 Prototyping Fe Si2 Iron Silicon Orthorhombic 1.51
04-004-4599 Prototyping Fe Si2 Iron Silicon Orthorhombic 1.51
04-006-9121 Prototyping Fe Si2 Iron Silicon Orthorhombic 1.51
04-007-1080 Star Fe Si2 Iron Silicon Orthorhombic 1.68
01-089-2024 Blank Fe Si2 Iron Silicon Tetragonal 3.33
01-073-1843 Indexed Fe Si2 Iron Silicon Tetragonal 3.63
03-065-2795 Indexed Fe Si2 Iron Silicon Tetragonal 3.99
