主题:【讨论】Are you satisfied with your salary?--Sign up on April 9th
浏览0 回复25 电梯直达
小M
Are you satisfied with your present salary? Do you want to gain more?
Will you choose job-hopping because of the present low salary?
该帖子作者被版主 天晴了10积分, 2经验,加分理由:sign post
abcdefghijkl123
I  am  not  satisfied with my  present salary.
该帖子作者被版主 smileqing1积分, 2经验,加分理由:sign
yuduoling
watertime
I'm not  satisfied with the present salary.
qlmkk
Although I am not satisfied the current salary,but I will not choose job-hopping because of the present low salary.I think I should not live for money......Money, enough on the line.
hxf119
I am not satisfied the current salary,but I will not choose job-hopping because of the present low salary。Beacause I'm just graduated
mengzhaocheng
移液器工程师
dahua1981
symmacros
Although I am not satisfied the current salary,I may still work in the present status. Salary is important, but work condition is also a key consideration, e.g. you may like this work, you go other place without this kind of equipment.
家有田
I  am  not  satisfied with my  present salary,but the present job can enrich me a lot experience.
