主题:【第六届原创】甲苯的代谢物尿中马尿酸的高效液相色谱测定法
浏览0 回复6 电梯直达
xinyi19881202
维权声明:本文为xinyi19881202原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
High-Performance Liquid Chromatography for the Determination of the Hippuric Acid as Urinary Metabolite of Toluene
                          Jie Liu, Yong Mei, YaNan Wang
College of Medicine, Wuhan University of Science and Technology, Wuhan 430065, China
Abstract
Objective:To establish a new analytical method for the determination of hippuric acid in human urine by HPLC. Method:Urine samples were collected at the end of the shift and analyzed for hippuric acid by HPLC with a uv/vis detector. A mixed solution of methanol/0.01mol/L phosphoric acid (40/60) as mobile phase was used. The detection was performed at λ=228nm, at 1.0ml/min. Results: The method showed good linearity in a range of 0.01mg/ml0.5 mg/ml with a correlation coefficient of 0.9999. The average relative standard deviations(RSDs) at three concentration levels of low, medium and high were 2.59%, 0.90%, 0.68% respectively, and the average recovery were 92.25%, 97.27%, 100.15% respectively. The minimum detection concentration was 0.41mg/L. Conclusion:The developed method was simple, reliable, and useful for the biologic monitoring of industrial exposure to toluene with high reproducibility and stability.
Keywords: HPLC; Urine; Hippuric acid; Toluene
xinyi19881202
arvid2007
xinyi19881202
还是未验证啊  这是怎么回事呀  第一次发帖不太清楚
社区=冬季=
天瑞俱乐部
原文由 xinyi19881202(xinyi19881202) 发表:
]参加原创论坛发一个帖(带附件)就可以的,其他的帖子我帮你删掉了。但请将参赛论文的标题改为中文哦~。另外,还需把论文电子版及参赛申请表发至指定邮箱;并邮寄至指定地址。
yuanzaitianbian
