主题:【转帖】发现奇果味觉欺骗的分子机制
zhang8826857
一项研究揭示出了奇果的“颠倒味道”的可能机制。当在舌头上放几分钟之后,来自西非的绰号是“奇果”的红色莓果的无味道的奇果蛋白能够让柠檬等酸味食物变成枫糖浆那样甜。这种效应会在1小时之内逐渐消失,这在一些科研人员以及有趣的是一些酒吧调酒员中广为人知,调酒员在所谓的“味觉颠倒聚会”上提供这种水果。Keiko Abe及其同事试图通过使用带有甜味受体(它帮助感受甜味)的人类细胞的实验室分析揭开奇果蛋白的秘密。这组作者报告说,当预先用奇果蛋白培养的细胞接触到一种酸溶液的时候,它们受到刺激的程度远远超过它们接触到中性溶液的时候。此外,缺乏这种受体的细胞不能对酸做出反应,这提示奇果蛋白与这种受体结合而且在接触到酸而非中性环境的时候不断激活它。此外,在中性环境下,这种蛋白阻断了阿斯巴甜和植物甜蛋白等甜味剂的甜味受体的活化。这组作者使用一个分子检验方法追踪人类味觉受体hT1R2的究竟哪一部分造成了奇果蛋白的感觉效应。这组作者说,这些发现提示了奇果的味觉欺骗的一种分子机制。
doi:10.1371/journal.pone.0019448
PMC:
PMID:
Human sweet taste receptor mediates acid-induced sweetness of miraculin
Ayako Koizumi, Asami Tsuchiya, Ken-ichiro Nakajima, Keisuke Ito, Tohru Terada, Akiko Shimizu-Ibuka, Loc Briand, Tomiko Asakura, Takumi Misaka, and Keiko Abe
Miraculin (MCL) is a homodimeric protein isolated from the red berries of Richadella dulcifica. MCL, although flat in taste at neutral pH, has taste-modifying activity to convert sour stimuli to sweetness. Once MCL is held on the tongue, strong sweetness is sensed over 1 h each time we taste a sour solution. Nevertheless, no molecular mechanism underlying the taste-modifying activity has been clarified. In this study, we succeeded in quantitatively evaluating the acid-induced sweetness of MCL using a cell-based assay system and found that MCL activated hT1R2-hT1R3 pH-dependently as the pH decreased from 6.5 to 4.8, and that the receptor activation occurred every time an acid solution was applied. Although MCL per se is sensory-inactive at pH 6.7 or higher, it suppressed the response of hT1R2-hT1R3 to other sweeteners at neutral pH and enhanced the response at weakly acidic pH. Using human/mouse chimeric receptors and molecular modeling, we revealed that the amino-terminal domain of hT1R2 is required for the response to MCL. Our data suggest that MCL binds hT1R2-hT1R3 as an antagonist at neutral pH and functionally changes into an agonist at acidic pH, and we conclude this may cause its taste-modifying activity.
该帖子作者被版主 dong36261积分, 2经验,加分理由:谢谢分享
dong3626
确实很奇怪?
造成味觉欺骗》?传递了错误的 信号。。呵呵
