主题:【第六届原创】【第四届原创】采用HRGC/ECNI-LRMS分析环境样品中的短链氯化石蜡
浏览0 回复2 电梯直达
gaoyuan82628
维权声明:本文为gaoyuan82628原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
论文标题:Optimized Cleanup Method for the Determination of Short Chain Polychlorinated n-Alkanes in Sediments by High Resolution Gas Chromatography/Electron Capture Negative Ion-Low Resolution Mass Spectrometry
摘要:The performances of three adsorbents, i.e. silica gel, neutral and basic alumina, in the separation of short chain polychlorinated n-alkanes (sPCAs) from potential interfering substances such as polychlorinated biphenyls (PCBs) and organochlorine pesticides were evaluated. To increase the cleanup efficiency, a two-step cleanup method using silica gel column and subsequent basic alumina column was developed. All the PCB and organochlorine pesticides could be removed by this cleanup method. The very satisfying cleanup efficiency of sPCAs has been achieved and the recovery in the cleanup method reached 92.7%. The method detection limit (MDL) for sPCAs in sediments was determined to be 14 ng g-1. Relative standard deviation (R.S.D.) of 5.3% was obtained for the mass fraction of sPCAs by analyzing four replicates of a spiked sediment sample. High resolution gas chromatography/electron capture negative ion-low resolution mass spectrometry (HRGC/ECNI-LRMS) was used for sPCAs quantification by monitoring [M-HCl]- ions. When applied to the sediment samples from the mouth of the Daliao River, the optimized cleanup method in conjunction with HRGC/ECNI-LRMS allowed for highly selective identifications for sPCAs. The sPCAs levels in sediment samples are reported to range from 53.6 ng g-1 to 289.3 ng g-1. C10- and C11- PCAs are the dominant residue in most of investigated sediment samples.
附件:
yuduoling
天瑞俱乐部
欢迎参加原创论坛大赛,记得按要求发电子邮件及邮寄纸质作品哦~~
