分子式或英文名称总的告诉一样吧,否则怎么查?
[请你将该物相的化学式告诉大家,以便帮你查找,你要知道人家不都是做水泥的,不懂你那个什么东西的缩写是什么意思。
(估计是Ca Al O H )
下面这些都是,你要哪种?]
PDF Overlay List (drag to shuffle, click on its column header to edit a number)
[111.txt] 20.000 4112
Phase ID (15 Overlays) Chemical Formula File ID I% 2T(0) d/d(0) RIR Wt% Tag XS(A) #d/I
Calcium Aluminum Oxide Hydrate Ca4Al2O7!xH2O PDF#02-0077 100.0 0.000 1.0000 ? 0.0 Major >1000 30
Calcium Aluminum Oxide Hydrate Ca3Al2O6!xH2O PDF#02-0083 100.0 0.000 1.0000 ? 0.0 Major >1000 30
Calcium Aluminum Oxide Hydrate Ca2Al2O5!8H2O PDF#11-0205 100.0 0.000 1.0000 ? 0.0 Major >1000 32
Calcium Aluminum Oxide Hydrate Ca2Al2O5!6H2O PDF#12-0008 100.0 0.000 1.0000 ? 0.0 Major >1000 24
Calcium Aluminum Oxide Hydrate CaAl2O4!10H2O PDF#12-0408 100.0 0.000 1.0000 ? 0.0 Major >1000 44
Calcium Aluminum Oxide Hydrate Ca4Al2O7!19H2O PDF#14-0628 100.0 0.000 1.0000 ? 0.0 Major >1000 39
Calcium Aluminum Oxide Hydrate Ca4Al2O7!19H2O PDF#14-0631 100.0 0.000 1.0000 ? 0.0 Major >1000 39
Calcium Aluminum Hydroxide Hydrate Ca2Al(OH)7!6.5H2O PDF#16-0339 100.0 0.000 1.0000 ? 0.0 Major >1000 34
Katoite, syn Ca3Al2(OH)12 PDF#24-0217 100.0 0.000 1.0000 ? 0.0 Major >1000 71
Calcium Aluminum Oxide Hydrate Ca4Al6O13!3H2O PDF#33-0254 100.0 0.000 1.0000 ? 0.0 Major >1000 48
Calcium Aluminum Oxide Hydroxide Hydrate Ca2Al(OH)7!3H2O PDF#33-0255 100.0 0.000 1.0000 ? 0.0 Major >1000 11
Calcium Aluminum Oxide Hydroxide Hydrate Ca6Al2O6(OH)6!32H2O PDF#41-0216 100.0 0.000 1.0000 ? 0.0 Major >1000 27
Calcium Aluminum Oxide Hydroxide Hydrate 3CaO!Al2O3!Ca(OH)2!18H2O PDF#42-0487 100.0 0.000 1.0000 ? 0.0 Major >1000 45
Calcium Aluminum Oxide Hydrate Ca2Al2O5!8H2O PDF#45-0564 100.0 0.000 1.0000 3.70 0.0 Major >1000 25
Caldecahydrite [NR] CaAl2O4!10H2O PDF#47-1882 100.0 0.000 1.0000 ? 0.0 Major >1000 19
