The centrate, containing polysaccharide material is then filtered through both the depth and the 0.35 μm filters in series. The product is then transferred through a closed system to the purification area for further processing.
It is difficult and inappropriate to translate the technical article based on the literal meaning of the text alone. What are the actual operation process and the setting up of apparatus?
