主题:【求助】与OOS/OOT相关的几个单词的翻译
浏览0 回复11 电梯直达
happy王子矜
1.可确定的实验室原因
在其他地方的sop里面查到翻译为 Lab Assignable Cause  ,这样写比Confirmable Lab's Cause更合适么?
2.确保调查的充分与科学性
里面的“确保”
这个词一般情况下在质量文件中如何写?
我查到两个单词
Ensure  /  Guarantee
哪个更合适一点呢?我看词条里面的解释好像用前者合适。但是保证试剂我知道是guarantee reagent,那么在这里选哪个好啊。
未完待续,最近会有很多英文方面的请教,打算一个大文件弄一次悬赏贴,写完一个发一个文件的分。为免受骚扰,解决问题后改悬赏。
poorlittle
I prefer “ensure”.  There are 41 “ensure” in ISO 17025 which is called the Bible of laboratory management.
happy王子矜
多谢楼上的。关于第一个疑问有什么可以建议的么?
poorlittle
This is my first time encountering the phase “可确定的实验室原因”.  It is difficult to understand without context (上下文).
2010/6/28 14:29:43 Last edit by poorlittle
myreebok
happy王子矜
可确定的实验室原因——有明显的证据、科学的判断及证明是实验室本身导致的超规/异常结果发生的相应原因。以下实验室误差的例子可认为是可确定的原因,包括但不限于:仪器错误,显著误差和经证实的显著误差等。
Lab Assignable Cause –Clear evidence, scientifically justified and documented is the lab’s cause of the OOS/Atypical result .The following examples of laboratory errors are considered as assignable causes, including but not limited to instrument error, observable error and confirmed observable error.
回微寒老师。以上为中英文关于可确定的实验室原因的解释。
poorlittle
Information :
Assignable : legally transferable to the ownership of another (from http://www.onelook.com/?w=assignable&ls=a ), seems irrelevant
Confirmable (通过某种途径来) 确定的,  (但不一定已确定了)
Confirmed ()确定的
Substantiated : 有证据支持的 supported or established by evidence or proof ( from http://www.onelook.com/?w=substantiated&ls=a )
I prefer : substantiated cause from the laboractory, or confirmed cause
2010/6/28 17:06:38 Last edit by poorlittle
happyjyl
参考英文原文最好看权威机构发布的内容。SOP不好找,guidance on industry很好找,也很有帮助。建议你看看FDA的指导原则。把这篇指导原则从头到尾看完,你的两个问题都会有答案了。
http://www.fda.gov/downloads/Drugs/GuidanceComplianceRegulatoryInformation/Guidances/ucm070287.pdf
poorlittle
原文由 poorlittle(poorlittle) 发表:
Information :
After reading the “Guidance on industry” recommended by happy, I searched with the keyword “assignable cause” (not just the word assignable) and got different definition for “assignable”
一个很好的教训!
2010/7/2 9:05:53 Last edit by poorlittle
happy王子矜
原文由 happyjyl(happyjyl) 发表:
谢谢~!我是没有时间进行系统的阅读和培训,没办法啊。要准备的其他东西太多了,翻译是放在最后的工作。完成的话锦上添花,完不成我也没法。
poorlittle
原文由 王子矜(wangzijin) 发表:
其实, 磨刀不误斩柴工。
Anyway, I would suggest you to use “assignable cause”
