主题:【求助】求助翻译一句话
浏览0 回复2 电梯直达
zting86919
The reversibly adsorbed mass of the physisorbed water was subtracted and the remaining mass change was
multiplied by the molecular weight of Cu2O divided by the atomic weight of oxygen.
总是弄不清楚这个英语中的乘啊、除啊的表达,请大家帮我看看,怎么翻译,谢谢~
wlb3628
(m-m(可逆吸收水))*M(Cu2O)/M(O)
该帖子作者被版主 happyjyl2积分, 2经验,加分理由:有效回复
happyjyl
原文由 wlb3628(wlb3628) 发表:
这样表达更正确些:
(m-m(可逆吸收水))* [M(Cu2O)/M(O)]
是先用the molecular weight of Cu2O除以the atomic weight of oxygen,再用得到的结果去乘以m与m(可逆吸收水)的差值.但楼上的计算结果是对的.
