主题:【资料】Handbook of Industrial Water Treatment
浏览0 回复2 电梯直达
环保得忍着等春天
环保得忍着等春天
PART Ⅰ Introduction
Chapter 01 Water Sources, Impurities and Chemistry......................3
Chapter 02 Environmental Considerations…………………………..13
Chapter 03 Applying Quality Methods………………………………..20
PATR Ⅱ External Treatment
Chapter 04 Aeration……………………………………………………27
Chapter 05 Clarification………………………………………………..34
Chapter 06 Filtration……………………………………………………44
Chapter 07 Precipitation Softening…………………………………...53
Chapter 08 Ion Exchange…………………………………………….68
Chapter 09 Membrane Systems……………………………………..100
PART Ⅲ Boiler Water Systems
Chapter 10 Boiler Feedwater Deaeration…………………………..106
Chapter 11 Preboiler And Boiler Corrosion Control………………..114
Chapter 12 Boiler Deposits: Occurence And Control……………..144
Chapter 13 Boiler Blowdown Control……………………………….159
Chapter 14 Boiler System Failures………………………………….172
Chapter 15 Chemical Cleaning Of Steam Generator Systems…..191
Chapter 16 Steam Purity……………………………………………..198
Chapter 17 Measurement Of Steam Purity………………………...207
Chapter 18 Steam Turbine Deposition, Erosion, and Corrosion…212
Chapter 19 Condensate System Corrosion………………………...219
Chapter 20 Fireside Preboiler Systems……………………………..233
Chapter 21 Boiler Fireside Deposit And Corrosion Control……….241
Chapter 22 Cold-End Deposition And Corrosion Control………….247
PART Ⅳ Cooling Water Systems
Chapter 23 Cooling Water Systems--Heat Transfer......................255
Chapter 24 Corrosion Control-Cooling Systems...........................260
Chapter 25 Deposit And Scale Control-Cooling System...............276
Chapter 26 Microbiological Control-Cooling System....................284
Chapter 27 Chlorine And Chlorine Alternatives............................300
Chapter 28 Macrofouling Control..................................................316
Chapter 29 Cooling Tower Wood Maintenance............................322
Chapter 30 Once-Through Cooling...............................................327
Chapter 31 Open Recirculating Cooling Systems.........................334
Chapter 32 Closed Recirculating Cooling Systems......................353
Chapter 33 Pretreatment Of Cooling Water Systems...................358
Chapter 34 Air Conditioning And Refrigeration Systems..............362
PART Ⅴ Chemical Feed and Control
Chapter 35 Chemical Feed Systems.............................................374
Chapter 36 Monitoring And Control Of Water Treatment..............401
PART Ⅵ Wastewater and Gas Cleaning Systems
Chapter 37 Wastewater Treatment................................................418
Chapter 38 Gas Cleaning Systems................................................444
PART Ⅶ Control Water Analyses and their Interpretation
Chapter 39 Analytical Methods and Equipment.............................455
Chapter 40 Expression of Analytical Results.................................459
jianmei97
原文由 环保得忍着等春天(chen-gyc) 发表:
呵呵,这可是我整理了好几天的资料吗
