先看英语期刊一般的要求: (1) Please use Times or Times New Roman, 12-point font, doublespaced throughout; this requirement holds for abstracts, body of the text, references, footnotes, tables, and all captions. (2) All tables and figures must be numbered consecutively, tables with Roman numerals and figures with Arabic numerals. Tables and figures may be integrated into the first draft of the text, which simplifies the review process, but figures should also be uploaded as individual files. (3) References should be collected in a list at the end of the document, following the conventions described later in these instructions. References should never appear as footnotes and footnotes should never appear in the reference list.
