【作者】 满莹; 宋铁兵; 王玉华; 肖威;
【Author】 MAN Ying1,SONG Tie -bing2,WANG Yu -hua2,XIAO Wei2 (1. The Second Affiliated Hospital of Heilongjiang University of Chinese Medicine,Harbin 150001,China; 2. Daqing Oilfield General Hospital,Daqing 163001,China)
【机构】 黑龙江中医药大学附属第二医院; 大庆油田总医院;
【摘要】 目的:采用HPLC-ELSD法测定通迪胶囊中三七皂苷R1和人参皂苷Rg1、Rb1的含量。方法:色谱柱DiamonsilC18(150mm×4.6mm,5μm),流动相:乙腈-水,梯度洗脱0~5min,乙腈20%~25%;5~20min,乙腈25%~45%;流速:1.0mL.min-1;柱温:25℃;漂移管温度:70℃;载气流速2.0L.min-1。结果:三七皂苷R1和人参皂苷Rg1、Rb1进样量分别在0.3~1.5μg(r=0.9997),1.5~7.5μg(r=0.9998)和1.5~7.5μg(r=0.9999)范围内呈良好的线性关系;平均回收率(n=6)分别为101.8%、102.1%、103.6%;RSD分别为1.6%、2.1%、1.8%。结论:HPLC-ELSO法结果准确,便于操作,可用于通迪胶囊的质量控制。 更多还原
【Abstract】 Objective:To develop the quantitative method of notoginsenoside R1,ginsenoside Rg1,and Rb1 in Tongdi capsules by HPLC -ELSD. Methods:The column was packed with a DiamonsilC18(150mm × 4. 6mm,5μm) stationary phase. The mobile phase consisted of acetonitrile -water,eluted in gradient mode(0 ~ 5min,acetonitrile 20% ~ 25% ;5 ~ 20min,acetonitrile 25% ~ 45% ) with flow rate of 1. 0ml.min -1. Column tem-perature was set at 25℃. The temperature of driftube was 70℃. Results:The linear ranges of notoginsen... 更多还原
【关键词】 HPLC-ELSD; 三七皂苷R1; 人参皂苷Rg1; 人参皂苷Rb1; 通迪胶囊;
【Key words】 HPLC -ELSD; notoginsenoside R1; ginsenoside Rg1; ginsenoside Rb1; Tongdi capsules;
