【作者】 曲彩红; 陶玲; 黄际薇; 郑琼良; 吴小林; 张振陆;
【Author】 QU Cai-hong~1 ,TAO Ling ~1, HUANG Ji-wei ~1,ZHENG Qiong-liang ~1,WU Xiao-lin~1,ZHANG Zhen-lu~2 (1.Department of pharmacy,The Third Hospital of Zhongshan University,Guangdong Guangzhou 510630,China;2.Guangzhou Ertiangtang Pharmaceutical Co.,Ltd,Guangdong Guangzhou 510500,China)
【机构】 中山大学附属第三医院; 广州二天堂制药有限公司 广东广州510630; 广东广州510630; 广东广州510500;
【摘要】 目的:建立用高效
液相色谱法(HPLC)测定白屈菜注射液中白屈菜碱的含量。方法:采用DiamonsilC18柱(4.6mm×250mm,5μm);流动相为乙腈0.01mol·L-1磷酸二氢钾梯度洗脱,柱温:35℃;流速:1mL·min-1;检测波长290nm。结果:白屈菜碱的线性范围为:0.1068~1.068μg,r=0.9996(n=6),平均回收率为99.12%,RSD为1.09%。结论:该方法稳定、结果准确,可作为白屈菜注射液的质量控制方法。 更多还原
【Abstract】 OBJECTIVE To establish a method for determining the content of chelidonine ofChelidonium majus injection by HPLC.METHODS Diamonsil C18 4.6 mm×250 mm,5 μm, column was used; acetonitrile-0.01 mol·L-1KH2PO4 as mobile phase; the temperature of column was 35 ℃;flow-rate was 1 mL·min-1; the detection wavelength was 290 nm.RESULTS The linear range of chelidonine was 0.106 8-1.06 8 μg(r=0.999 6,n=6),the average recovery was 99.12%,RSD was 1.09%.CONC... 更多还原
【关键词】 白屈菜注射液; 白屈菜碱; 高效
液相色谱法;
【Key words】 Chelidonium majus injection; chelidonine; HPLC;
