【作者】 江文明; 陈钧; 谢月玲; 高小玲; 蒋新国;
【Author】 JIANG Wen-ming,CHEN Jun,XIE Yue-ling,GAO Xiao-ling,JIANG Xin-guo(Department of Pharmaceutics, School of Pharmacy, Fudan University, Shanghai 200 032, China)
【机构】 复旦大学药学院药剂学教研室; 复旦大学药学院药剂学教研室 上海200032; 上海200032; 上海200032;
【摘要】 目的:建立测定人血浆中尼扎替丁的高效
液相色谱方法。方法:采用DiamonsilC18色谱柱(200mm×4.6mm,5μm),流 动相为0.1mol·L-1醋酸铵缓冲液 甲醇(60∶40),检测波长为320nm。血浆样品加盐析溶液碱化后以氯仿提取,雷尼替丁为内标。 结果:尼扎替丁血药浓度线性范围为20~6000μg·L-1(r=0.9999,n=6),最低检测浓度为10μg·L-1(S/N=3),方法回收率在 96.84%~101.39%(n=5),日内和日间RSD均小于4%。结论:本法简便,快速,重现性好,适于尼扎替丁的药动学研究。 更多还原
【Abstract】 OBJECTIVE To establish a HPLC method for the determination of nizatidine in human plasma.METHODS Nizatidine was extracted from human plasma using chloroform after basified with salting-out agent,and then separated on a Diamonsil C 18 column ( 200 mm × 4.6 mm, 5 μm).The mobile phase consisted of water( 0.1 mol · L -1 ammonium acetate)-methanol(60∶40 ). Ranitidine was used as the internal standard and the wavelength of detection was set at 320 nm.RESULTS The linear range was 20- 6 000 μg·L -1(r = ... 更多还原
【关键词】 尼扎替丁; 高效
液相色谱法; 测定;
【Key words】 nizatidine; HPLC; determination;
