【作者】 吕洁; 孟祥军; 郭妍;
【Author】 Lu Jie1,Meng Xiangjun2,Guo Yan1 (1.Vocational College,Liaoning University of TCM,Shenyang,Liaoning,China 110101; 2. Shenyang Medical College,Shenyang,Liaoning,China 110034)
【机构】 辽宁中医药大学职业技术学院; 沈阳医学院;
【摘要】 目的建立用高效
液相色谱法测定阿魏酸川芎嗪口崩片含量的方法。方法色谱柱为Diamonsil-C18柱(250mm×4.6mm,5μm),以用三乙胺调节pH=7.6的0.02mol/L磷酸二氢钾溶液-乙腈(320∶60)为流动相,检测波长320nm,流速1.0mL/min,外标法定量。结果阿魏酸川芎嗪分离完全,进样量在6.4~9.6μg范围内线性关系良好。阿魏酸线性回归方程为Y=6162969.58X-7471917.60,r=1.000;川芎嗪线性回归方程为Y=4237015.65X-3057438.64,r=1.000。阿魏酸平均回收率为99.4%,RSD=1.76%(n=9);川芎嗪平均回收率为98.9%,RSD=2.38%(n=9)。结论该方法快捷、简便、准确,可作为阿魏酸川芎嗪口崩片的含量测定方法。 更多还原
【Abstract】 Objective To establish a method for determining Ligustrazine Ferulate Orally Disintegrating Tablet by HPLC.Methods Diamonsil- C18 column(250 mm× 4.6 mm,5 μ m)was used.Acetonitrile- 0.02 mol/L potassium dihydrogen phosphate( 60 ∶ 320,with triethylamineto adjusting pH=7.6) was the mobile phase and the detection wavelength was 320 nm.Results A good linearity was obtained in the range of 6.4- 9.6 μ g for ferulic acid.The linear equation was Y=6 162 969.58X- 7 471 917.60,r=1.000 for ligustrazine feru... 更多还原
【关键词】 阿魏酸川芎嗪; 口崩片; 高效
液相色谱法;
【Key words】 Ligustrazine Ferulate; orally disintegrating tablet; HPLC;
