93.1 高效
液相色谱法测定咽炎颗粒中大黄素的含量
【作者】 王丽; 张山川; 徐珽; 律焱; 唐尧;
【Author】 WANG Li(West China School of Pharmacy,Sichuan University,Chengdu 610041,China)WANG Li,XU Ting,TANG Yao(Department of Pharmacy,West China Hospital,Sichuan University,Chengdu 610041,China)ZHANG Shanchuan(West China Hospital of Stomatology,Sichuan University,Chengdu 610041,China)LV Yan(West China School of Public Health,Sichuan University,Chengdu 610041,China)
【机构】 四川大学华西药学院; 四川大学华西口腔医院; 四川大学华西医院药剂科; 四川大学华西公共卫生学院; 四川大学华西医院药剂科 成都市610041四川大学华西医院药剂科; 成都市610041;
【摘要】 目的:建立以高效
液相色谱法测定咽炎颗粒中大黄素含量的方法。方法:色谱柱为Diamonsil C18(150mm×4.6mm,5μm),流动相为甲醇-0.1%磷酸水溶液(68∶32),检测波长为254nm。结果:大黄素进样量在0.26~3.90μg范围内线性关系良好(r=0.9999),平均回收率为96.73%(RSD=1.49%)。结论:本法准确、灵敏、重现性好,操作简便、可用于控制咽炎颗粒的质量。 更多还原
【Abstract】 OBJECTIVE:To establish an HPLC method for determination of Emodin in Yanyan granules.METHODS:The stationary phase was Diamonsil C18(150mm× 4.6mm,5μ m)column and the mobile phase was methanol-0.1% phosphoric acid(68∶ 32),with detection wavelength set at 254nm.RESULTS:Within the range of 0.26~ 3.90μ g Emodin had a good linearity,and the average recovery was 96.73%(RSD=1.49%).CONCLUSION:The method is accurate,sensitive,reproducible,simple and can be used for the quality control of Yanyan granules. 更多还原
【关键词】 咽炎颗粒; 大黄素; 高效
液相色谱法; 含量测定;
【Key words】 Yanyan granules; Emodin; HPLC; Content determination;
