Jim Collins的从优秀到卓越英文版
Chapter 8 : The Flywheel and the Doom Loop
In this chapter Collins takes the notion of the flywheel concept one step further. He emphasizes that when companies went from good to great there was “no miracle moment”. No technological breakthrough. No special announcement. Rather, the accumulated effect of dedicated work finally blossoming on an exploding basis. These findings are in alignment with what Napoleon Hill wrote in Think and Grow Rich decades ago. He said, “The most successful people have a burning desire for a particular purpose”. Success didn’t come overnight, even though it may have appeared that way to outsiders. Dedication and commitment to purpose builds people and companies of great wealth. Similarly, this flywheel can work in reverse, which Collins refers to as the “doom loop”.
The Flywheel and The Doom Loop
Good-to-great transformations often look like dramatic, revolutionary events to those observing from the out-side, but they feel like organic, cumulative processes to people on the inside. The confusion of end outcomes (dramatic results) with process (organic and cumulative) skews our perception of what really works over the long haul. Those companies had no name for their transformations; there was no launch event, no tag line, no programmatic feel whatsoever. There was, in other words, no miracle moment in the transformation of each company from good to great.
Each went through a quiet, deliberate process of figuring out what needed to be done to create the best future results, then they simply took those steps, one by one over time, until they hit their breakthrough moments.
The Flywheel Effect
Their successes can be seen in the following illustration: Imagine an enormous, heavy flywheel — a massive disc mounted horizontally on an axle, measuring 30 feet in diameter, two feet in thickness and 5,000 pounds in weight. In order to get the flywheel moving, you must push it. Its progress is slow; your consistent efforts may only move it a few inches at first. Over time, how-ever, it becomes easier to move the flywheel, and it rotates with increasing ease, carried along by its momentum. The breakthrough comes when the wheels own heavy weight does the bulk of the work for you, with an almost unstoppable force. Each of the good-to-great companies experienced the flywheel effect in their transformations. The first efforts in each transformation were almost imperceptible. Yet, over time, with consistent, disciplined actions propelling it forward, each company was able to build on its momentum and make the transformation — a build-up that led to a breakthrough. The momentum they built was then able to sustain their success over time. These companies understood a simple truth: Tremendous power exists in the fact of continued improvement and the delivery of results. Point to tangible accomplishments —
however incremental at first — and show how those steps fit into the context of an overall concept that will work. When this is done in such a way that people see and feel the buildup of momentum, they will line up with enthusiasm. This is the real flywheel effect. When a leader lets the flywheel do the talking, he or she does not need to fervently communicate the organizations
goals — people can just extrapolate from the momentum of the flywheel for themselves. As people decide among themselves to turn the fact of potential into the fact of results, the goal almost sets itself. People want to be part of a winning team, producing visible, tangible results.
© www.hrfolks.com All Rights Reserved
The Doom Loop
Other companies exhibited very different patterns. Instead of a quiet, deliberate process of figuring out what needed to be done, then doing it, these companies frequently launched new programs — often loudly, with the aim of “motivating the troops” — only to see those programs fail to produce sustained results. They pushed the flywheel in one direction, stopped, changed course and pushed it in a new direction, a process they repeat-ed continually. After years of lurching back and forth, these companies failed to build sustained momentum and fell into what could be termed the doom loop.
Are You on the Flywheel or in the Doom Loop?
How can you tell if your organization is on the fly-wheel, or in the doom loop? Consider the following:
You’re on the flywheel if you—
Follow a pattern of buildup, leading to break-through.
Confront the brutal facts to see what steps must be taken to build momentum.
Attain consistency with a clear Hedgehog Concept, staying within the three circles.
Follow the pattern of disciplined people, thought and action.
Harness appropriate technologies to your Hedgehog Concept, to accelerate momentum.
Spend little energy trying to motivate or align people; the momentum of the flywheel is infectious.
Maintain consistency over time.
You’re in the doom loop if you—
Skip buildup and jump right into breakthrough.
Implement big programs, radical change efforts, dramatic revolutions and chronic restructuring.
Embrace fads and engage in management hoopla, rather than confront the brutal facts.
Demonstrate chronic inconsistency, lurching back and forth and straying outside the three circles.
Jump right into action, without disciplined thought, or first getting the right people on the bus.
Spend a lot of energy trying to align and motivate people, rallying them around new visions.
Sell the future to compensate for lack of results in the present.
The Flywheel and the Doom Loop are metaphors for demonstrating how great companies start out slowly and methodically yet eventually reach the sustained momentum needed for breakthrough results. In this chapter Collins shows how each of the companies on the good to great list went through a period of buildup before it achieved breakthrough success. Companies that moved too quickly, and tried to skip the buildup phase, often saw their success shrivel and fade away. Those that underwent a steady changeover phase, followed by careful implementation, went on to achieve great things.
Sustainable transformations follow a predictable pattern of buildup and breakthrough. Like pushing on a giant, heavy flywheel, it takes a lot of effort to get the thing moving at all, but with persistent pushing in a consistent direction over a long period of time, the flywheel builds momentum, eventually hitting a point of breakthrough.
