原文由 poorlittle(poorlittle) 发表:
Suggestion ;
The sample was extracted with ethyl acetate and purified with silica.
detected by GC-NPD, qualitative two-pillar and amount of external standard. – Where is the verb?
detected。 这句少主语。本身是想用前句的主语,但是他用了句号。如果改为逗号,then detected by。。。就差不多了。
In the range of 0.002~0.03mg/kg , the recovery (n=6) is 82.3~100.1% ,with RSD of 1.7~5.1%.
The limit of determination is 0.006mg/kg for triadimenol and 0.002mg/kg for the rest of the 6 pesticides
原文由 水番(psq0513) 发表:
大家好,我写的论文,审稿老师让我把英文摘要需要修改一下,我做了一下修改,我怕写的不好,请大家再帮我修改一下,谢谢了!
"摘要:建立了应用配有NPD检测器的气相色谱仪检测蔬菜中涕灭威、异丙威、嘧霉胺、莠去津、三唑醇、噻嗪酮、抑霉唑残留量的方法。样品采用乙酸乙酯提取,硅胶柱净化,旋蒸定容后上机检测。以GC-NPD测定,外标法定量。7种农药添加浓度在0.002~0.03mg/kg时,回收率在82.3%~100.1%之间,相对标准偏差在1.7%~5.1%之间。检测限分别为:三唑醇0.006mg/kg,其它6种为0.002mg/kg。"
"Abstract:The method of determining aldicarb,isoprocarb,pyrimethanil,atrazine,triadimenol,buprofezin,Imazalil in vegetable was established.The sample was extracted with ethyl acetate and in the purifying process Silica was used . detected by GC-NPD, qualitative two-pillar and amount of external standard. In the range of 0.002~0.03mg/kg , recoveries (n=6) were 82.3~100.1% ,with RSD of 1.7~5.1%.The limits of determination were respectively: triadimenol are 0.006mg/kg, any other 6 pesticides are 0.002mg/kg ."
原文由 水番(psq0513) 发表:
